Factory Presets Dual Tones
titchyblackcat
Does anyone have the Pod HD Dual Tones Bundle that came installed on the HD500
I'd like this on My Pod HD but it has a different list when you do a factory reset.
Someone has also come up with software to convert between the different HD series files so it should be OK.
Brilliant.
Thanks very much guys.
How do you use the converter ? I downloaded it and an error message says it is not a valid win32 application.
You just select the format that your unit works. If you have a Pod HD500X for example, it will be ".5xe". After that you select the format of the file you want to convert. Then you select the folder that the file you want to convert is in and at last you run it.
Hope this helps.
