rudomat Posted August 7, 2015 Share Posted August 7, 2015 is it possible to store individual input levels per preset, so i can switch between electric and acoustic...? thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 7, 2015 Share Posted August 7, 2015 The levels for the 1/4" inputs are global settings. You'd be better off using the Aux in for your acoustic. If you truly need a line level input for the acoustic, you would want to use one of the 1/4" returns. I've used an acoustic with a preamp with my HD500 many times, and I've always been fine just going into either the guitar in or aux in. And I believe the Helix inputs have more headroom than the HD500. Quote Link to comment Share on other sites More sharing options...
rudomat Posted August 14, 2015 Author Share Posted August 14, 2015 The levels for the 1/4" inputs are global settings. You'd be better off using the Aux in for your acoustic. If you truly need a line level input for the acoustic, you would want to use one of the 1/4" returns. I've used an acoustic with a preamp with my HD500 many times, and I've always been fine just going into either the guitar in or aux in. And I believe the Helix inputs have more headroom than the HD500. thanks, but the aux input inpedance is not 1 kohm, right...? sorry...i meant 1 megohm of course...so can somebody verify if it´s 1 megohm then...? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 14, 2015 Share Posted August 14, 2015 thanks, but the aux input inpedance is not 1 kohm, right...? I believe the Aux in is 1 Mohm. With something like a signal from an acoustic guitar, the input impedance is really not important, though. It becomes an issue with magnetic pickups, but you should be fine with an acoustic. The only issue would be if it's just too hot. Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 14, 2015 Share Posted August 14, 2015 If your acoustic employs a built in preamp with Battery , the Aux input on Helix should be OK even if it has typical 20K impedance , Edit FWIW HD500 Aux input has 1Meg impedance , I expect the same on Helix. http://line6.com/support/page/kb/_/pod/pod-hd/pod-hd500xhd500-impedance-specifications-r142 1 Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted August 14, 2015 Share Posted August 14, 2015 thanks, but the aux input inpedance is not 1 kohm, right...? sorry...i meant 1 megohm of course...so can somebody verify if it´s 1 megohm then...? The Aux In is 10 Ohm 10 kOhm. It's designed for very hot pickups, or even a line-level signal. If you're looking for additional instrument inputs, the Returns are your best bet—they can be set to instrument level and then selected as one of your four paths' input blocks. EDIT: Since Helix's guitar input has 123dB of dynamic range, and the HX audio engine is 32-bit floating point, there's no issue with running a Volume/Pan > Gain block right after the Input block to control input volume per preset. Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 14, 2015 Share Posted August 14, 2015 The Aux In is 10 Ohm. Hey, I was only off by 999,990 Ohms... :blink: Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 14, 2015 Share Posted August 14, 2015 The Aux In is 10 Ohm. It's designed for very hot pickups, Now that's innovation! ( or a typo?) or perhaps 10k Ohm ? Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted August 14, 2015 Share Posted August 14, 2015 D'oh! Yeah, I read the manual, which has a typo. Yeah, 10 kOhm. Quote Link to comment Share on other sites More sharing options...
Jose7822 Posted August 14, 2015 Share Posted August 14, 2015 Speaking of which, where's the manual? :-) Quote Link to comment Share on other sites More sharing options...
