iriusman Posted November 5, 2015 Share Posted November 5, 2015 Hi, my Variax Standard finally arrived, and lovely it is. The manual, though, is astonishingly unhelpful. I worked out how to connect the device by USB (couldn't find a single instruction on the subject in the manual), what software I needed to download (Line6 Monkey. Wouldn't have been too hard to mention that, would it?) But Workbench won't install, because it appears it's not compatible with Mac OSX systems beyond Mountain Lion, and I'm running El Capitan. I did download Workbench HD. Is that the software I should be using? It refuses to recognise the guitar when it's plugged in via the USB interface, though Line6 Monkey seemed to find it all right. Can anyone help? Quote Link to comment Share on other sites More sharing options...
iriusman Posted November 9, 2015 Author Share Posted November 9, 2015 Well, I submitted a support ticket, and finally worked it out. You do use Workbench HD. You have to plug in both the USB connector and a jack plug, into the guitar and turn on the modelling switch, for Workbench HD to 'see' it. Line6 Monkey works fine on my El Capitan. Not completely intuitive. Quote Link to comment Share on other sites More sharing options...
clay-man Posted November 13, 2015 Share Posted November 13, 2015 USB = guitar communicates with computer Jack = turns on guitar for computer to see, and you can hear what the edits sound like live. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 13, 2015 Share Posted November 13, 2015 Unfortunately, the USB interface does not power the guitar. You need to power the guitar with batteries and turn it on with the jack. Quote Link to comment Share on other sites More sharing options...
grundyhome Posted December 8, 2015 Share Posted December 8, 2015 Well, I submitted a support ticket, and finally worked it out. You do use Workbench HD. You have to plug in both the USB connector and a jack plug, into the guitar and turn on the modelling switch, for Workbench HD to 'see' it. Line6 Monkey works fine on my El Capitan. Not completely intuitive. I was told that Workbench won't run on El Capitan. Were you able to get it installed? I didn't have Workbench installed before I upgraded to El Capitan. When I try to install Workbench on El Capitan, I get an message that the OS isn't supported. Line6 support confirmed Workbench is not currently supported on El Capitan. Quote Link to comment Share on other sites More sharing options...
iriusman Posted December 8, 2015 Author Share Posted December 8, 2015 It installed for me, and seems to work fine. I got the 'not supported' message during installation, but clicked through anyway. Bit of a slow response from Line6, though, isn't it? Quote Link to comment Share on other sites More sharing options...
Variax_Eugene Posted December 8, 2015 Share Posted December 8, 2015 I am running El Capitan and successfully installed Workbench and Line 6 Monkey. Not sure what I did right! Quote Link to comment Share on other sites More sharing options...
wheelnut Posted January 2, 2016 Share Posted January 2, 2016 Line 6 Monkey 1.7 and Workbench HD 2.12.0 are both running well on my 2014 MacBook Air with El Capitan 10.11.2. I didn't get any warnings on installation. Quote Link to comment Share on other sites More sharing options...
amsdenj Posted April 22, 2016 Share Posted April 22, 2016 I have Line 6 Monkey and Workbench HD installed on Mac OS X 10.11.4 and they seem to be running. I have the Variax USB interface plugged in and there's a green light on the USB side. I have the VDI cable plugged into the guitar, and a 1/4" cable to turn on the battery, and have pressed the Guitar Model Switch and see the LED lit up (in red). But The Variax USB interface flashes read on the guitar side, and the guitar won't connect in Workbench HD or show up as selectable in Line 6 Monkey. Any ideas? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 26, 2016 Share Posted April 26, 2016 I have Line 6 Monkey and Workbench HD installed on Mac OS X 10.11.4 and they seem to be running. I have the Variax USB interface plugged in and there's a green light on the USB side. I have the VDI cable plugged into the guitar, and a 1/4" cable to turn on the battery, and have pressed the Guitar Model Switch and see the LED lit up (in red). But The Variax USB interface flashes read on the guitar side, and the guitar won't connect in Workbench HD or show up as selectable in Line 6 Monkey. Any ideas? That stupid dongle is a royal pain in the a$$...do you have a POD? I've always had better luck connecting through that. Just got everything up and running on a new macbook with 10.11.4, no issues. When I have used the dongle, I always had to connect to Monkey first. As long as that worked, Workbench would then recognize the guitar. Going straight to Workbench never seemed to work. Who knows why. . Quote Link to comment Share on other sites More sharing options...
garry9133 Posted April 29, 2016 Share Posted April 29, 2016 Hi Iknowathingortwo, You have to have a 1/4" guitar cable plugged into the guitar's output. (It doesn't need to be connected to anything at the other end. All it does is switch on the guitar's electronics. It's just a battery saving feature...the same as some stomp pedals) Quote Link to comment Share on other sites More sharing options...
