rudomat Posted November 17, 2015 Share Posted November 17, 2015 can you set the unit, so it reads the actual state while recalling....? if not - how do you store the recall Levels, while you have an Expression pedal working as a volume pedal...? thanks Quote Link to comment Share on other sites More sharing options...
glideman Posted November 17, 2015 Share Posted November 17, 2015 There's another thread about volume levels where one of the Line 6 guys said the next firmware will give the ability to set a global setting that will match the expression pedal position when changing presets, I believe. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 17, 2015 Share Posted November 17, 2015 ... meantime, the stored level of the pedal will be whatever state/position it is in at the moment that you Save the preset. Quote Link to comment Share on other sites More sharing options...
TNJ1956 Posted November 23, 2015 Share Posted November 23, 2015 I want to set up my Helix with exp 1 as a wah pedal, and exp 2 as a volume pedal. Toggle from 1 to 2, wah to volume, and vice versa. How does one accomplish that, specifically (could I get an algorithmic answer)? S. j Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 23, 2015 Share Posted November 23, 2015 I want to set up my Helix with exp 1 as a wah pedal, and exp 2 as a volume pedal. Toggle from 1 to 2, wah to volume, and vice versa. How does one accomplish that, specifically (could I get an algorithmic answer)? S. j You are in luck. This is the default setup for the Helix. Any preset that has a volume and a wah block will set up automatically this way. Quote Link to comment Share on other sites More sharing options...
rudomat Posted November 23, 2015 Author Share Posted November 23, 2015 I want to set up my Helix with exp 1 as a wah pedal, and exp 2 as a volume pedal. Toggle from 1 to 2, wah to volume, and vice versa. How does one accomplish that, specifically (could I get an algorithmic answer)? S. j no problem...no idea, weather it´s algorythmic or not... the only thing you got to realize is, when you switch to wah, you´re automatically on max gain...i´ve installed a minus boost of 6 dB or so on one switch for the case i want wah on rhythm volume level... Quote Link to comment Share on other sites More sharing options...
TNJ1956 Posted November 30, 2015 Share Posted November 30, 2015 What I did was leave the expression pedal in exp1. Then I saved the Wah (Fessler) to a footswitch. I hate having to stomp so hard on the pedal, and now I just step on the f/s and start up the effect. S. j Quote Link to comment Share on other sites More sharing options...
