arislaf Posted January 15, 2016 Share Posted January 15, 2016 If for example I want to put more trail to the delay? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 15, 2016 Share Posted January 15, 2016 I think you have to do that with a pedal controller, setting the min/max positions of the pedal as desired. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted January 15, 2016 Share Posted January 15, 2016 Press and hold the Delay's Feedback knob. Helix jumps to the Controller Assign page for that parameter. Press Knob 6 (Learn Controller) and then the footswitch you want it assigned to. If desired, tweak the min and max values. Press HOME to exit. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 15, 2016 Share Posted January 15, 2016 Well, there you go. Learn something new everyday. Just curious - does the footswitch take on the min value when ON and max value when OFF (or vice versa)? If not something like that, how does a non-sweep controller operate with min/max values? Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 15, 2016 Share Posted January 15, 2016 Well, there you go. Learn something new everyday. Just curious - does the footswitch take on the min value when ON and max value when OFF (or vice versa)? If not something like that, how does a non-sweep controller operate with min/max values? It just toggles between them. I guess in some sense, max is on (the scribble strip label is bolded), and max is off (label is dimmed). Quote Link to comment Share on other sites More sharing options...
arislaf Posted January 15, 2016 Author Share Posted January 15, 2016 Thanks a lot guys, that is an awesome feature!! Quote Link to comment Share on other sites More sharing options...
