d0stenning Posted February 11, 2016 Share Posted February 11, 2016 When you're recording your first loop do you always have to start playing the first note of the loop ( beat 1 ) the moment you hit the RECORD stomp pedal - or is there a way you can press the stomp and then start playing the idea, say a second or more later ( after "record panic" has gone ) then having pressed the stomp to stop recording - go back and - while the loop is still playing - change the point at which the first loop starts - in other words cutting out the first blank second that was recorded ? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 11, 2016 Share Posted February 11, 2016 Short answers are yes and no respectively. Yes you have to hit the Start switch the instant of the first 'beat' and th Stop Recording switch at the same instant after the last 'beat'. Of course, the recorder has no concept of beats. And no, there is no way to erase part of a loop. Quote Link to comment Share on other sites More sharing options...
d0stenning Posted February 11, 2016 Author Share Posted February 11, 2016 yet.... time for an "IdeaScale" ;) Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 11, 2016 Share Posted February 11, 2016 yet.... time for an "IdeaScale" ;) I am not sure whether editing the loop will ever happen but I have used loopers that essentially have a "ready" state that starts the loop the moment a note is struck. There have also been some ideas floating around for adding the capability to have longer and more loops available through some kind of memory card add on. This might give you the ability to edit your loops in a DAW on a PC. Quote Link to comment Share on other sites More sharing options...
d0stenning Posted February 11, 2016 Author Share Posted February 11, 2016 There have also been some ideas floating around for adding the capability to have longer and more loops available through some kind of memory card add on. That was my idea - for some add-on pedal type device that would not only house and support a memory card slot but also some other added value functionality - connected over USB to the Helix. The add-on functionality might for example be just an extra pedal, maybe with a single footstep switch - or a small 4/8 pedal unit with scribble-strips for each - because frankly the more you appreciate the power of those Helix scribble trips - you want MORE pedals-with-scribble-strips ! they're awesome. This extra "pedalboard-thing" would be designed style-wise to look exactly as the HELIX does ( without the colour Display ). Heres the FR: http://line6.ideascale.com/a/dtd/Extend-Looper-capability-with-add-on-unit-w-SDHC-memory-card/802351-23508 For example it would be great just to have all the controls for the looper we currently get by pressing on the looper block - have all those appear instead in this extra add-on unit - thereby leaving the pedals on the HELIX in their normal pedalboard state - so no more having to exit the looper to change tones/effects and then go back into the looper. This add-on unit could also be more than just the memory card interface but also have on board all the looping functionality itself. That way this device could actually be sold JUST as a new looper - but one with SDHC AND.... with those lovely scribble-strips! AND with the ability of being used as an extension pedalboard for the HELIX - that also makes the looper so much more user friendly. Specially on stage.. And if such an add-on had the ability to looping by itself - that would also release some DSP power back to the HELIX to be used by other effects blocks instead ! AND by being a separate external looper one wouldn't have to worry quite so much about switching patches. Quote Link to comment Share on other sites More sharing options...
d0stenning Posted February 11, 2016 Author Share Posted February 11, 2016 And heres an Ideascale suggestion for L6 to add the missing functionality I discuss here: http://line6.ideascale.com/a/dtd/Looper-a-way-to-trim-time-from-when-first-loop-was-recorded/805696-23508?submitted=1 Quote Link to comment Share on other sites More sharing options...
Guitarzman Posted February 23, 2016 Share Posted February 23, 2016 Does anyone know how to keep the looper on the same preset while adding a different tone on another preset? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 23, 2016 Share Posted February 23, 2016 Place the looper in POST position in both presets. Assign the looper in both presets to a footswitch. Pressing the footswitch in either preset will cause Helix to enter Looper mode. When switching to the next preset, configured as just stated, the Looper will continue to be active (e.g. will continue to play back the loop). Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 23, 2016 Share Posted February 23, 2016 Place the looper in POST position in both presets. Assign the looper in both presets to a footswitch. Pressing the footswitch in either preset will cause Helix to enter Looper mode. When switching to the next preset, configured as just stated, the Looper will continue to be active (e.g. will continue to play back the loop). Some additional things to note - you need to make sure that you're using the same version of the looper in each preset. If you're using the stereo version in one preset, you have to use it in the other as well. Also, the looper has to be in the same tone path in each preset. Quote Link to comment Share on other sites More sharing options...
Guitarzman Posted February 23, 2016 Share Posted February 23, 2016 Place the looper in POST position in both presets. Assign the looper in both presets to a footswitch. Pressing the footswitch in either preset will cause Helix to enter Looper mode. When switching to the next preset, configured as just stated, the Looper will continue to be active (e.g. will continue to play back the loop). Great thank you ... Quote Link to comment Share on other sites More sharing options...
Guitarzman Posted February 23, 2016 Share Posted February 23, 2016 Some additional things to note - you need to make sure that you're using the same version of the looper in each preset. If you're using the stereo version in one preset, you have to use it in the other as well. Also, the looper has to be in the same tone path in each preset. Thank you Phil... Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 23, 2016 Share Posted February 23, 2016 Great thank you ... If you're interested in some further reading on this topic...... http://line6.com/support/topic/17997-using-helix-looper-live/?view=findpost&p=133475 Quote Link to comment Share on other sites More sharing options...
