spikey Posted February 21, 2016 Share Posted February 21, 2016 Sorry for the obvious, but I plan on using some Mission Controller pedals for volume, Wah and for whatever, and I assume that there is a "Calibrate Controller pedal #1,2,3 etc" setting in the system setup inside the Helix. Is this correct? I did have a look in the Faq pages section but didn't find anything... Thanks! Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 21, 2016 Share Posted February 21, 2016 Sorry for the obvious, but I plan on using some Mission Controller pedals for volume, Wah and for whatever, and I assume that there is a "Calibrate Controller pedal #1,2,3 etc" setting in the system setup inside the Helix. Is this correct? I did have a look in the Faq pages section but didn't find anything... Thanks! I think the calibrate function on the Helix is supposed to be automatic. As far as I know there is no explicit calibration process. Quote Link to comment Share on other sites More sharing options...
spikey Posted February 22, 2016 Author Share Posted February 22, 2016 Well thats interesting. Thanks. I just assumed (theres that word again) since the Axe FX II and the Kemper had a calibration tab (to set the min-max heel-toe settings) for the controllers, the Helix would also. Oh yea I also am guessing that "any" Mission controller will work, and not just the ones with the "Line-6" marking? Quote Link to comment Share on other sites More sharing options...
glideman Posted February 22, 2016 Share Posted February 22, 2016 Mission for Kemper didn't work right. Had to buy the Line 6 compatible one. None of my other pedals worked either. Quote Link to comment Share on other sites More sharing options...
spikey Posted February 22, 2016 Author Share Posted February 22, 2016 Mine are Mission EP-1 pedals. They did work with the Axe FXII and Kemper. Im hoping that they also work with Helix. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted February 22, 2016 Share Posted February 22, 2016 I know calibration is automatic, but I wish there was a calibration function. I have an expression that goes 0 to about 98 or so, unless I press hard. And 90 % of the sweep is at the last centimeter of travel. Log vs linear make no difference. I know its most likely due to pot sweep inside. Bring on manual calibrations. It would be nice to set the ends and middle. Quote Link to comment Share on other sites More sharing options...
spikey Posted February 22, 2016 Author Share Posted February 22, 2016 I did run crossed this thread- http://line6.com/support/topic/16994-need-expression-pedal-help/ Where is shows how to modify a Mission EP-1 to work with Helix. Looks like Ill have to pull out the soldering gun soon... Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted February 22, 2016 Share Posted February 22, 2016 I know calibration is automatic, but I wish there was a calibration function. I have an expression that goes 0 to about 98 or so, unless I press hard. And 90 % of the sweep is at the last centimeter of travel. Log vs linear make no difference. I know its most likely due to pot sweep inside. Bring on manual calibrations. It would be nice to set the ends and middle. I Agree! Mine wont go to 0 either.. only down to about 2%... Manual mapping could save me from this lollipop :) Quote Link to comment Share on other sites More sharing options...
