ticaw Posted February 25, 2016 Share Posted February 25, 2016 So i have my ux1 for years now and it worked perfectly on 2 laptops , both on Vista, windows 7 , windows 8 and 8.1Now I have to use it on a windows 10 laptop and it's not working.I installed everything I had to install, I tried downgrading the drivers , installed everything again 3 times and nothing. Initially there was no input and when I started tweaking and reinstalling stuff I finally got a signal, a super low signal with a HUGE feedback sound (i had to use the asio4all driver to get the signal).From what I can tell , I can't select the ux1 as an input in my recording devices. I really need to get this fixed...Thanks in advance! Quote Link to comment Share on other sites More sharing options...
guiradn666 Posted February 26, 2016 Share Posted February 26, 2016 i get the same problem ... i have win 10 i install my drivers and soft, i test with windows sound ... huge crack sound i can't make anything with that ... Quote Link to comment Share on other sites More sharing options...
ticaw Posted February 26, 2016 Author Share Posted February 26, 2016 This is really important and I really need it fixed... Quote Link to comment Share on other sites More sharing options...
aleshin Posted February 27, 2016 Share Posted February 27, 2016 I too got it problem after install win 10 x64: freez sound What can I do ? In win 7 and 8.1 I dont have it problem ... Quote Link to comment Share on other sites More sharing options...
aleshin Posted February 28, 2016 Share Posted February 28, 2016 Any news about resolve freeze sound ??? ((( It very bad ... May be anyone can help me ??? Quote Link to comment Share on other sites More sharing options...
Svartsol Posted February 28, 2016 Share Posted February 28, 2016 I've bought my ux1 two days ago. I installed the latest Drivers and I just checked other threads and saw that others have the same or a similar problem. I've no Input and Output Signal. please help! Quote Link to comment Share on other sites More sharing options...
ticaw Posted February 28, 2016 Author Share Posted February 28, 2016 I see that I'm not alone, this is unacceptable :/ Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 8, 2016 Share Posted March 8, 2016 Select 16 bit 46kHz bit/sample rate and see if that works for you. this was an early solution to the Win10 problem, I thought Line 6 had updated their drivers accordingly. Quote Link to comment Share on other sites More sharing options...
ticaw Posted March 8, 2016 Author Share Posted March 8, 2016 where should I select that? cause I've tried a bunch of things already Quote Link to comment Share on other sites More sharing options...
RhoadesDoug Posted March 9, 2016 Share Posted March 9, 2016 me too.. windows 10 and now I'm stuck.. Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 9, 2016 Share Posted March 9, 2016 If you run Monkey and have green ticks for everything and are still having issues check your power setting scheme. I do not have Win10 so do not know the specifics. Also try different USB ports. If you still have an issue please call Line6 directly or open a support ticket. Although official Line6 reps drop in evey now and then, this is a user forum and not a direct line to support. Quote Link to comment Share on other sites More sharing options...
ticaw Posted March 9, 2016 Author Share Posted March 9, 2016 If you run Monkey and have green ticks for everything and are still having issues check your power setting scheme. I do not have Win10 so do not know the specifics. Also try different USB ports. If you still have an issue please call Line6 directly or open a support ticket. Although official Line6 reps drop in evey now and then, this is a user forum and not a direct line to support. everything is updated on monkey. I re-installed the drivers a few times and nothing... tried a bunch of usb ports too what do you mean by power setting scheme? Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 9, 2016 Share Posted March 9, 2016 In the control panel there are power settings. In the advance power settings you could try to disable selective USB suspending. Also, just to eliminate some simple things, for general use make sure you are selecting the UX1 as the default sound device. For DAW use, make sure you are selecting the Line6 ASIO drivers in your DAW's setup and enabling the appropriate inputs and outputs. (The inputs and outputs likely will not be available for enabling until you select the Line6 ASIO driver in your DAW’s setup). Quote Link to comment Share on other sites More sharing options...
juanviavelez Posted December 22, 2019 Share Posted December 22, 2019 Same problem. Line6 UX1 doesn´t work with my official Windows 10. Everything in green on Line6 Monkey, but fuzz noise Quote Link to comment Share on other sites More sharing options...
pmisha Posted January 8, 2020 Share Posted January 8, 2020 Happens to me on my laptop, although work fine when I connect to a desktop. It's clear that the UX1 drivers is faulty and it's about time this being prioritized and fixed. Quote Link to comment Share on other sites More sharing options...
zielonykrawat Posted March 11, 2020 Share Posted March 11, 2020 @ticaw, @aleshin, @Svartsol, @juanviavelez did you solve the problem It's the same for me. A few days ago I was upgrading win7 to win10 and the sound was distorted, in addition, when playing movies, the picture frames. Ux1 issue Win10.wmv Quote Link to comment Share on other sites More sharing options...
stealthkiller Posted April 2, 2020 Share Posted April 2, 2020 Same Problem.... no Sound and Monkey Updater doesnt work as well... why? Every time i try to update monkey it tells me "Failed to launch installer" Quote Link to comment Share on other sites More sharing options...
michaellulko Posted April 9, 2020 Share Posted April 9, 2020 Same here, all of a sudden the ux1 crashes and it never used to do it. Can't update the drivers as well, and the Line 6 Updater shows nothing too. Quote Link to comment Share on other sites More sharing options...
shmanmani Posted November 28, 2020 Share Posted November 28, 2020 same here/ really annoing. Win 10 and UX1 simply not working. it seems to recognize it, but nothing is recorded. does line6 ignore us onpurpase? I have the latest driver, BTW. Help!! Quote Link to comment Share on other sites More sharing options...
RedCorsair Posted February 27, 2023 Share Posted February 27, 2023 there is solution for crackling-freezing sound: you should put it into usb 2, not 3 (also used 2015's drivers) Quote Link to comment Share on other sites More sharing options...
