Rick 12, Still Lacking Realism?
I have a real Rick 12 that I play through an old Vox AC-30 and it sounds sweeeeeet!  The Rick 12's in my JTV-89 are ok, but not that real sounding. When I tune the JTV-89 a whole step down and play the G string anywhere on the first 5 frets the octave sounds weird, buzzy.  My POG2 sounds better.  Also, the high E and B strings don't even sound doubled.  Your thoughts?
Side bar:  The "D" string sounds like a ring modulator when lightly picked over the treble pickup in some spots.  Is this a known anomaly?
PS:  I've put foam under the strings between the nut and tuners.  Didn't help.
1. My first guess is your guitar may need a setup, any slightly buzzing strings will make the modeling do funny things. If you mean you are physically tuning your strings down a full step to D standard you may need to go to a slightly heavier string to compensate for the loss of tension, also this will change your intonation... I normally tune my JTV89 down to D, I am using the stock strings as supplied from the factory and haven't noticed anything weird yet but I don't really use the 12 strings (have always thought the Variax Rickenbacker models sounded weak, hopefully this will be fixed in the new 2.0 firmware) , I do recall from what I read in the old forums that the 12 strings in the Variax have always seemed to be more prone to making weird noises at the slightest bit of fret buzz, tho I may not be remembering this correctly.
2. Have you tried changing the tuning of the octave strings in Workbench? If you cannot hear the doubling on the high E and B you should be able to adjust the level and the amount of detuning to bring them out more.
3. In addition to the foam under the strings at the headstock you may wish to try adding the small Velcro strip or other material of your choice under the strings at the bridge as shown in this thread:  http://line6.com/support/message/485558#485558
Thanks Johnny.  There was some buzz initially.  I raised the action, adjusted the neck and put 11's on.  Not too much buzz now, if any.  I haven't tried using Workbench.  I'm still looking for a tutorial.  If you know of one that walks you through it in "how to" procedures and not just a features summary, I'd appreciate it.
The info you need is probably here: http://www.vettaville.nl/vvworkbenchtutorials.html
You can probably figure it out pretty quickly even without the tutorials, it is fairly simple. Connect guitar. Start Workbench. You will see a list of models in the guitar, click the one you want to modify, change the tuning or whatever else you want to adjust, and save it to the guitar. You can always go back to the Factory version or make more adjustments if you change your mind later. You should give it a try and if you have any questions just post them here and people will help.
i'd go a step further, and say the real secret isn't even learning how to use workbench...
you really need to learn how to build and mod guitars...
workbench is just an extension of that... i somehow doubt you'd ever find a full and accurate tutorial on that subjective topic...
but workbench is easy... and powerful, if you know what you're doing or just don't mind experimenting (like myself)
In #2 are you saying that by using Workbench, can you independently adjust the volume of each string and detune the E & B strings of the 12 string models?
i believe that you can only detune the "offset" and not the individual strings on the 12 strings... but i've never bothered... just an FYI... if i recall correctly.
The simulated octave/doubled strings are detunable - I think this is the same thing you mean by "offset"? If he is having trouble hearing the octave/doubled simulated strings detuning them slightly will bring them out a little more, make it sound a little more realistic.
exactly like +/- some hz
but not like changing the low e octave string to a b or anything like that... so not a full alt tune, more like a slight detune.
Thanks guys. The E & B strings do not sound doubled and naturally chorusing like a real 12 string would, but instead like a single E & B string on a 12 string guitar.
So, as was stated before, you need to fireup your Workbench and detune those strings a little more which can be done on a string by string level in Workbench. Let us know if that helps. I always thought the electric 12 strings were a little lacking but I don't have one or access to one so I have no way of comparing. You're input would be greatly appreciated if you found a way to improve them.
I'll be experimenting soon.  I'll keep you posted.  I just resolved another issue today with copying and saving a model to Custom 2.  Evidently this procedure needs to be done quickly or it "times out" and wont save.
I'd be really interested to hear what you come up with, comparing your Ricky-12 to the Variax.  Please share, and if you could, make a video or audio recording showcasing your findings!  I am reminded that the model is of ONE particular instrument, but if you can A/B the two and not tell which is which, that's the real test.  Thanks!
I think the best test of the accuracy of the JTV modeling might be an A/B comparison of the 5 "Custom 1" models in the JTV89 and the 5 mag positions of the JTV 89. The closer those sounds are the closer we might assume the other modeled sounds are to the original guitars modeled as well - none of the "different pickups, different wood" etc. variables as when comparing say a new Strat to the Strat models in the JTV.
I have been planning to do an A/B vid but have not yet had time/opportunity, was hoping someone would have done one by now... from the limited noodiling around I have done on the JTV mags the models seem pretty close, tho the guitar seems to react slightly differently depending on whether mags or models are chosen (not referring to palm muting here).
I can't vouch for the authenticity....
BUT...
you might want to try again:
With all-new Variax HD technology, James Tyler Variax provides instant access to a huge collection of HD guitars with unprecedented depth, character and detail—making it the ultimate recording guitar.
Variax HD Upgrade
This free upgrade delivers a world-class collection of HD guitars rebuilt from the ground up using Line 6’s next-generation HD modeling technology, resulting in unprecedented sonic character and a more natural playing experience. From rare vintage electrics to classic acoustics and exotics, each HD instrument delivers superior articulation and exceptional feel—perfect for capturing inspired performances.
All-New Workbench HD Software
The all-new Workbench HD software makes it possible to build one-of-a-kind custom guitars by combining the HD body styles, HD pickups and components in unique ways. Featuring an intuitive, easy-to-use interface, Workbench HD provides full control over scores of important instrument characteristics such as string pitch, string volume, pickup position and much more. Workbench HD also lets you select any Variax pickup model and use it with the natural tone and response of your physical James Tyler Variax guitar—or blend the Variax HD signal with the magnetic pickup sound to create hybrid instruments.
The Ultimate Recording Guitar
Recording guitarists have always had to contend with the challenges of selecting the right guitar for the right tones, tuning/retuning issues, pickup noise in the studio, mics and mic preamps for acoustic guitars, and more. James Tyler Variax eliminates these problems—so you can concentrate on nailing your performance.
  • Free Variax HD upgrade features an extensive collection of HD guitars, so you can record with a palette of the world’s greatest instrument sounds.
  • With a world-class collection of HD acoustic guitars and exotic instruments, you can record acoustic tracks with pristine sound quality—without ever having to set up a microphone or a mic preamp.
  • With virtually limitless alternate tunings, you can easily switch between tunings while tracking.
  • The HD guitar tones in James Tyler Variax are completely free of pickup noise, so you can capture pristine takes without hum.
  • With James Tyler Variax, there’s no need to interrupt the creative flow by finding, tuning and acclimating to the feel of a new instrument. You can easily switch between HD guitars and tunings just by turning the model knob—enabling you to stay in the moment.
The Variax HD upgrade and Workbench HD software are compatible with all James Tyler Variax guitars. Download the updates from Line6.com.
