pilottes Posted April 30, 2016 Share Posted April 30, 2016 Is it possible to toggle between one and the other by assigning a footwitch other the the Toe Switch. Let say I assign the amp gain parameter to vary smootly with the position of EXP 1. To switch from EXP 2 (volume) to EXP 1 I would have to press the expression pedal toe switch to toggle to EXP 1 but maxing out the volume in doing so. I want to move this ability to switch to a normal footswitch FS-1-5 or FS 7-11. ... Quote Link to comment Share on other sites More sharing options...
myalteregohamish Posted May 1, 2016 Share Posted May 1, 2016 I'd love an answer to this issue to. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted May 1, 2016 Share Posted May 1, 2016 You can't move the EXP toe switch elsewhere, but you can use another switch to toggle between, say Volume and Wah and leave both controlled by the same EXP: On the Footswitch Assign page, change the assignment of both the Volume and Wah blocks to the to the desired footswitch. On the Controller Assign page, change the assignment of one of them so they're the same. If both blocks are on (or both off), select one and press BYPASS. Pressing the switch will then toggle between control of Volume and Wah. Unfortunately, this doesn't really apply when assigning a Volume block and a Gain parameter to the same footswitch. In this case, to avoid the EXP toe switch, the best solution is to simply connect a second expression pedal. Quote Link to comment Share on other sites More sharing options...
pilottes Posted May 1, 2016 Author Share Posted May 1, 2016 That,s what I was afraid of. It's as good a reason as any to buy more stuff. Thanks D_I Quote Link to comment Share on other sites More sharing options...
zooey Posted May 2, 2016 Share Posted May 2, 2016 You can't move the EXP toe switch elsewhere Any plan to make that possible at some point? Doesn't seem a likely inherent limitation. Quote Link to comment Share on other sites More sharing options...
Bangha Posted May 2, 2016 Share Posted May 2, 2016 I suggested this implementation on ideascale in December I think. I'm having a hard time logging in to post the link on here, still, if you guys can please vote for the idea! Once I'm back on my laptop I'll track down the link. Quote Link to comment Share on other sites More sharing options...
dinodave321 Posted May 22, 2017 Share Posted May 22, 2017 The solution I came up with to assigning exp toe to a foot switch was as follows. Set a toggle CC (59) midi message out on the switch of your choice on the same channel as your helix is set to, set dim value to 0, set lit value to 127 in command centre. This goes out the midi out port thru my H9s (which have to set to midi thru) back into the helix switching the expression pedal without having to max out my volume to make the switch, Cool !!! Of course you need to daisy chain all your midi pedals with the last one returning back into the Helix midi input, and check that midi thru is off on the Helix (Global Settings > Midi/Tempo) , to stop the midi message looping and switching between the two exp pedals 50 times a second If you don't have or are not using external midi pedals (I haven't actually tried this but I can't see why it wouldn't work) try the above with a midi lead straight across the Midi in and out ports on the Helix. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 23, 2017 Share Posted May 23, 2017 ... If you don't have or are not using external midi pedals (I haven't actually tried this but I can't see why it wouldn't work) try the above with a midi lead straight across the Midi in and out ports on the Helix. Cool idea! Don't know what i would use this for as I can usually set things up with the proper stomp or snapshot assignment but I could see this coming in handy sooner or later. 1 Quote Link to comment Share on other sites More sharing options...
manubsingh Posted October 26, 2018 Share Posted October 26, 2018 On 5/1/2016 at 1:26 PM, Digital_Igloo said: You can't move the EXP toe switch elsewhere, but you can use another switch to toggle between, say Volume and Wah and leave both controlled by the same EXP: On the Footswitch Assign page, change the assignment of both the Volume and Wah blocks to the to the desired footswitch. On the Controller Assign page, change the assignment of one of them so they're the same. If both blocks are on (or both off), select one and press BYPASS. Pressing the switch will then toggle between control of Volume and Wah. Unfortunately, this doesn't really apply when assigning a Volume block and a Gain parameter to the same footswitch. In this case, to avoid the EXP toe switch, the best solution is to simply connect a second expression pedal. I know this is an old post, but I thought this might be better than reposting the same question. Hello everyone (former Fractal guy to now Helix). I'm trying to figure out how to do these instruction but I don't seem to understand it. I'm trying to essentially have my volume pedal EXP1 switch to a Wah Pedal (without changing the volume) with a footswitch. Are the instructions on how I can do that? Quote Link to comment Share on other sites More sharing options...
reginaldStjohn Posted October 26, 2018 Share Posted October 26, 2018 All the instructions are really saying is assign both wah and volume blocks to the same footswitch. Make sure that EXP1 is controlling them the way desired. Using Edit or the Helix itself make sure that one effect is on and one off. Now save. When you step on the footswitch one will turn on and the other off. The EXP1 is controlling both of them all the time it just makes one of the effects bypass while turning the other on. The problem with this is that if it turns off the volume block then it will change your volume. what you really want to do is switch to EXP2 with a footswitch which I am not sure you can do. Quote Link to comment Share on other sites More sharing options...
vimuston Posted October 26, 2018 Share Posted October 26, 2018 Make two snapshots, one for wah EXP1 one for volume/whatever EXP2. Which EXP is selected is remembered per snapshot. Use 4 snapshot/4 stomp mode ai you can switch between the two with a footswitch. Quote Link to comment Share on other sites More sharing options...
kevin627 Posted November 14, 2019 Share Posted November 14, 2019 On 5/23/2017 at 6:51 AM, dinodave321 said: The solution I came up with to assigning exp toe to a foot switch was as follows. Set a toggle CC (59) midi message out on the switch of your choice on the same channel as your helix is set to, set dim value to 0, set lit value to 127 in command centre. This goes out the midi out port thru my H9s (which have to set to midi thru) back into the helix switching the expression pedal without having to max out my volume to make the switch, Cool !!! Of course you need to daisy chain all your midi pedals with the last one returning back into the Helix midi input, and check that midi thru is off on the Helix (Global Settings > Midi/Tempo) , to stop the midi message looping and switching between the two exp pedals 50 times a second If you don't have or are not using external midi pedals (I haven't actually tried this but I can't see why it wouldn't work) try the above with a midi lead straight across the Midi in and out ports on the Helix. Unfortunately I use my MIDI out port to control a pedal that doesn't have a MIDI thru. I saw there is a post on ideascale, it would be great (and probably not too complicated) to implement this. Edit: https://line6.ideascale.com/a/dtd/Toggle-Expression-Pedal-selection-with-Footswitch/967640-23508 Quote Link to comment Share on other sites More sharing options...
