slappyjoe Posted May 2, 2016 Share Posted May 2, 2016 just gettin my head round pod farm & reaper...Now stuck on recording vocals. viewed the help online but when i go to pod farm "mixer view" and look for drop down menu below line 6 logo to change from instruments to mic input ..its not there..(the drop down menu with option) Any ideas~~~~~~~~~~~~~~? Thanks. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 2, 2016 Share Posted May 2, 2016 What audio interface are you using? What microphone? Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 hi ux2 with reaper tbone condenser mic all working fine through guitar amp to test, using monitor for recording. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 2, 2016 Share Posted May 2, 2016 What device is providing phantom power to your condenser mic? What device is connected to your computer that reaper communicates with? Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 Not sure I understand questions...Mic connecting to line6 ux2 via the Mic input...! ..on phantom power. & ux2 connected to laptop via usb. Pod farm & gearbox are installed Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 2, 2016 Share Posted May 2, 2016 Not sure I understand questions...Mic connecting to line6 ux2 via the Mic input...! ..on phantom power. & ux2 connected to laptop via usb. Pod farm & gearbox are installed That's the info that you didn't provide earlier. Hence my questions. Have you downloaded and installed the Line 6 driver for the UX2? Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 2, 2016 Share Posted May 2, 2016 Also, make sure you're launching the standalone POD Farm. The plug-in will have no input options. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 2, 2016 Share Posted May 2, 2016 Also run the Monkey to make sure your divers are up to date. Depending on when this unit was first registered, you may be entitled to POD Farm 2. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 2, 2016 Share Posted May 2, 2016 Try going into the mixer view in PF select mic as your source. The UX2 has a phantom power button AND volume controls on top. What Triryche sez is true - my UX2 -> PF2. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 Hi yes, deleted and reinstalled drivers as they werent working at start so line6 & pod farm should be fine..all lights green! And notification of registration received Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 Billybee..That's the advice I was following on thread but no drop-down menu below line 6 logo to choose Mic input Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 2, 2016 Share Posted May 2, 2016 There should be a "mixer view" - I'm not at home so I can't fire PF up but its there, unless its for PF standalone. :) BTW I know what you are going through I went hunting for it myself years ago. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 Stand alone pod farm? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 2, 2016 Share Posted May 2, 2016 Pod Farm runs either stand alone (without using a DAW like reaper for recording) or as a plug-in for processing signalks within a DAW like reaper. Since you are using Reaper for recording, have you tried selecting the UX-2 MIC as the record input in Reaper? In other words after arming the Reaper track for recording select the track's Record Input source in Reaper rather than within Pod Farm. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 2, 2016 Share Posted May 2, 2016 BTW be sure you've ran the Monkey and got all green checks for the UX and then went through the License Manager for the UX as well. Then fire up PF2.5. There should be an "inputs tab" if its all good. I would get the vocals going first with PF then fire up Reaper. Depending on the age of the UX you might have to go to PF1 (free) if PF2.5 isn't authorized. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 2, 2016 Share Posted May 2, 2016 Yes you can buy PF as a standalone meaning you do not have to have the UX plugged in in order to use it. When you bought the UX it came with the ability to use PF (as its dongle). So if you have a UX you have to have it plugged in and connected for PF. If you bought PF on its own its all good. Was driving me nuts! Right next to the Line 6 emblem (About Button) in the middle to the right is the Mixer View button. Page 3.23 of the manual - input source menu is at the top. Hope that works for ya. Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 2, 2016 Share Posted May 2, 2016 Stand alone pod farm? By standalone I was referring to the direct monitoring mode of POD Farm, not the actual standalone hardware independent version BilBee is referring to. You can launch POD Farm from a desktop shortcut or the start menu, which would be the Tone Direct Monitoring monitoring, or you can launch it as VST plug-in from within Reaper, that version will not have mic/instrument input selections as it uses the track you apply it to as the input. When do get it sorted, you can capture the processed sound you hear along with the unprocessed signal and then apply the POD Farm plug-in post processioning . Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 2, 2016 Share Posted May 2, 2016 The mixer view button would be the first button to the right of the logo not below. If its not there then I am sure one of the fellas might know. But that how I've used it myself. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 Thanks for the advice, really appreciate this, I'll go over it all again tonite and reply with results...fingers crossed! Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 I launched it as vst with reaper(just reread posts). Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 2, 2016 Share Posted May 2, 2016 Yes. So in reaper after arming the vocal track for recording, select the UX2 mic as the track's recording input source. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 2, 2016 Author Share Posted May 2, 2016 will try that Silver ..thanks, Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 3, 2016 Author Share Posted May 3, 2016 Sorry.. Armed track for recording but can't see any option for ux2 Mic.. (or anything relating to vocals). Tried the send drop-down..nothing!.. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 3, 2016 Share Posted May 3, 2016 Hmmm.... I think you should open a support ticket to work directly with Line 6 tech support on this. http://line6.com/support/tickets/add.html Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 3, 2016 Share Posted May 3, 2016 Wow I was hoping this was fixed. Well a couple of questions: Have you ran the L6 Monkey and did everything come up "green checks"? Next Run the L6 License Manager and Make sure it is registered and Authorized, k? That was all for the UX getting connected and making sure "it's all good". So if the UX is connected and all drivers and stuff are good then, Start Pod Farm and go to the about screen - IIRC its under the "help tab". It should tell you if the UX is good and authorized to run that version of Pod Farm. Some UXs are authorized for PF1 some are for PF2 btw. Can you get the mic to work with just the UX and Pod Farm (no Reaper)? Can you try a non-phantom powered mic? You have to get the PC to "see" the UX and/or the mic. BTW - silly question but does the UX and PF work for guitar in? :) Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 3, 2016 Author Share Posted May 3, 2016 Pod farm2 about tells me I'm running in trial mode , all line 6 software fine (green) Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 3, 2016 Share Posted May 3, 2016 Is this a new unit? If so you need to run license manager. If it is not new, depending on when it was first registered, you may only be entitled to POD Farm 1. IIRC the cutoff date was Oct 2010, but don't quote me. Getting back to mic selection, did you try launching from the desktop? (Not as a VST within Reaper) That is how you can get to the mic selection. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 3, 2016 Author Share Posted May 3, 2016 ok lads..latest. condenser mic up n running, pod farm says connected to ux2 and shows mic1 in the dropdown mid left..dont know what i did apart from downloading the software again..its not a new unit bought second hand but pristine ,,dont think was ever used..when i go to reaper i have just the input mono and input stereo send 1/2 but mic is recording. not sounding great on mic, is it just a case of playing around with it now and where should i go on pod farm for best mic sound...gear/panel/presets..etc? think i see now that i can run effects from pod farm on pc or on reaper .. thanks a million for your patience , no doubt ill be back ..hope i can be of similiar life saving help to someone in same boat! Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 4, 2016 Share Posted May 4, 2016 Congrats Dude! Glad it worked out, now get back to rockin'!! :D Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 4, 2016 Author Share Posted May 4, 2016 Wheeee. Thanks. Quote Link to comment Share on other sites More sharing options...
slappyjoe Posted May 4, 2016 Author Share Posted May 4, 2016 thanks to Trirche, Billbee & Silverhead for your invaluable assistance... Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 4, 2016 Share Posted May 4, 2016 think i see now that i can run effects from pod farm on pc or on reaper .. A workflow I like is to capture unprocessed and processed simultaneously. In Reaper’s preferences enable all 4 inputs from the UX2. Arm 2 tracks to record. One track will be 1/2 and the other 3/4. Then in POD Farm’s mixer allocate one pair of sends unprocessed and the other processed. With this method you will have the your dry track that you can then apply the POD Farm plug-in to for tweaking after recording just in case you are not happy with the processed. Btw, I think there may be some vocal presets in POD Farm to use as starting points. Quote Link to comment Share on other sites More sharing options...
