zartimus Posted July 19, 2016 Share Posted July 19, 2016 I just got a beatBuddy drum pedal. I want to record song ideas into the Spider Jam so I plug the drum pedal in MP3/CD 1/8 inch jack, the guitar into the guitar jack and when I record (with input set to guitar) I just get just the guitar. If I plug the beat buddy into the 1/4 inch AUX and set the input yo AUX/MIC I get clean drums and no guitar. If I hold down the input button for 2 seconds and select "mix with guitar" then I get drums and guitar recorded but the drums share the overdrive tone used for the guitar and gets all distorted (this is not input level distortion, it's from the tone/dist effect). Am I missing a way to record a clean beat buddy pedal and the distorted guitar sound on the Spider Jam? The routing seems odd. Think of it as playing your own backing track into the spider via the MP3 input and playing along, BUT you want to record it to the Spider JAM's internal recording. Can't seem to do it without mono-ising it as a WAV and moving it to the SD card.. Quote Link to comment Share on other sites More sharing options...
rarellano Posted July 19, 2016 Share Posted July 19, 2016 Maybe helps (page A.3 of Spider Jam Advanced Guide [Rev B]): Aux Track DistortionQ: When I use the Aux track for recording my guitar track and I add Aux FX Presets, myguitar sometimes sounds distorted when I play it back; it sounds fine while recording. What’s up?A:When recording to the Aux track, you’re essentially in “input monitor†mode,meaning you’re hearing your guitar’s input, not its output. When you add Aux FX likeEQ, for example, you’re also boosting level. This can result in distortion that you onlyhear on playback. The cure for this is, if you’re recording on the Aux track and you’reboosting your level with Aux FX, simply lower your input level to avoid distortion. Quote Link to comment Share on other sites More sharing options...
zartimus Posted July 20, 2016 Author Share Posted July 20, 2016 Maybe helps (page A.3 of Spider Jam Advanced Guide [Rev B]): Aux Track Distortion Q: When I use the Aux track for recording my guitar track and I add Aux FX Presets, my guitar sometimes sounds distorted when I play it back; it sounds fine while recording. What’s up? A: When recording to the Aux track, you’re essentially in “input monitor†mode, meaning you’re hearing your guitar’s input, not its output. When you add Aux FX like EQ, for example, you’re also boosting level. This can result in distortion that you only hear on playback. The cure for this is, if you’re recording on the Aux track and you’re boosting your level with Aux FX, simply lower your input level to avoid distortion. Thanks for checking! I had given that a try already. When i change to a clean sound the distortion on the drums goes away. That's why I don't think it's input level distortion, it's from the tone/dist effect. I will run through that again though, just in case I msised something.. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 20, 2016 Share Posted July 20, 2016 (edited) I don't think it can be done. I have a beat buddy and when I get some time I'll see if I can record the guitar and unprocessed drums at the same time with the Spider Jams recorder but if I recall correctly I had trouble trying to do it a while ago and gave up. I usually just plug the BB into the CD/mp3 jack and play along with the drums and then mic the amp using a mic and my X3 Pro or HD500 or just using a USB mic into my computer. Edited July 20, 2016 by Brazzy Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 20, 2016 Share Posted July 20, 2016 I don't know for sure about the Spider Jam but I do know that the CD/MP3 input in the POD products can't be recorded over the POD's USB connection to the DAW. That's because the CD/MP3 analog input signal is passed directly to the device outputs. It is not converted within the POD to a digital format and hence is not available for the USB output. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 20, 2016 Share Posted July 20, 2016 I don't know for sure about the Spider Jam but I do know that the CD/MP3 input in the POD products can't be recorded over the POD's USB connection to the DAW. That's because the CD/MP3 analog input signal is passed directly to the device outputs. It is not converted within the POD to a digital format and hence is not available for the USB output. Thanks for explaining the Pod part of it silverhead. I'm going to see what I can get the Sider Jam to do at some point. Quote Link to comment Share on other sites More sharing options...
