joguitar 0 Posted July 21, 2016 After upgrade the fw (2 to 2.01) everytime Helix rebuild the preset! Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted July 21, 2016 Did you reset the device after updating by holding down FS 9&10 while powering on? Quote Share this post Link to post Share on other sites
joguitar 0 Posted July 21, 2016 yes, i made it! after device reset it rebuild everything at factory. import my setlist, play... and shut down. When power on Helix it rebuild again ... Quote Share this post Link to post Share on other sites
rbum 1 Posted July 21, 2016 As I understood so far, after re-importing the own (old) presets, one should update these with FS 10 &11 while powering on: http://www.helixhelp.com/pmwiki.php?n=Main.ResetOptions Quote Share this post Link to post Share on other sites
joguitar 0 Posted July 21, 2016 Yes... now it's seems working good! Quote Share this post Link to post Share on other sites
jasdadgad 40 Posted July 21, 2016 As I understood so far, after re-importing the own (old) presets, one should update these with FS 10 &11 while powering on: http://www.helixhelp.com/pmwiki.php?n=Main.ResetOptions That worked for me too! Thanks for the tip. Quote Share this post Link to post Share on other sites
HonestOpinion 937 Posted July 21, 2016 As I understood so far, after re-importing the own (old) presets, one should update these with FS 10 &11 while powering on: http://www.helixhelp.com/pmwiki.php?n=Main.ResetOptions This is not what the firmware notes say. They specify to reset using FS 9 & 10 while powering on and then to reload your saved presets. Are you saying you should do an additional FS 10&11 reset after having done the FS 9&10 reset and loading your old presets? Can anyone from L6 confirm this? Quote Share this post Link to post Share on other sites
duncann 758 Posted July 21, 2016 I don't have any problems after the 9 & 10 thing, then reloading backed-up presets without manually rebuilding them. I don't think the 10 & 11 combo needs to be done because I've noticed after importing presets from the previous firmware, then shutting the device off, the next time it's turned on it rebuilds these automatically anyway. Quote Share this post Link to post Share on other sites
rng52465 1 Posted July 21, 2016 I tried updating, resetting and I'm only getting a Boot Failure message. HELP!!! Quote Share this post Link to post Share on other sites
rbum 1 Posted July 21, 2016 I see this only as an option and that worked for me updating to 2.0 when Helix started to rebuild hundreds of preset erverytime I switched it on. I did the same this time right after resetting my globals and importing my presets, and at least it did no harm. I don't think it's a "must do" , but obviously it can help in certain situations. Quote Share this post Link to post Share on other sites
