Dshow Posted July 24, 2016 Share Posted July 24, 2016 Hi, does anyone know how to setup cubase so that it changes snapshots? I tried to load a song into cubase and then send a midi command to change the snapshot or activate a footswitch but didn't have any success. When I dial the bank and program manually it changes setlist and patches but couldn't figure out how to automate it. Any hint? Thanks Quote Link to comment Share on other sites More sharing options...
mykejb Posted July 24, 2016 Share Posted July 24, 2016 MIDI CC 69 is supposed to do this - values are 0-7 for snapshots 1-8 Mike Quote Link to comment Share on other sites More sharing options...
bc05 Posted July 25, 2016 Share Posted July 25, 2016 Is this performed simply by using Helix as an interface via USB? IE not special mdi cables or setup required? Just Midi controller info in Cubase? Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 25, 2016 Author Share Posted July 25, 2016 Is this performed simply by using Helix as an interface via USB? IE not special mdi cables or setup required? Just Midi controller info in Cubase? That's whats the plan and it should work fine. Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 25, 2016 Author Share Posted July 25, 2016 MIDI CC 69 is supposed to do this - values are 0-7 for snapshots 1-8 Mike Thanks for the reply. I know the CC numbers are, but I couldn't figure out how tell cubase to change automatically when playing to the recording. It's a cubase specific question I guess. I was just wondering if anybody already doing this. Quote Link to comment Share on other sites More sharing options...
mykejb Posted July 25, 2016 Share Posted July 25, 2016 I've not tried it, but you should be able to add a MIDI track, route it to the Helix and use it to send the CC. From memory here, so might be missing something, but this is roughly how to do it I think ... Create the MIDI track and add a MIDI event to it (Draw tool) Double click the event to open the MIDI editor Add a new controller lane -it'll default to velocity. Click where it says "velocity" and it'll give you a list of MIDI CC and other control types. 69 probably isn't listed but I there's an option to add it, I think it's in setup on the dropdown menu. Select CC69, add it to the list the go back and select it. Use Draw to add the CC events and you should be able to add/change the snapshots Mike Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 25, 2016 Author Share Posted July 25, 2016 I've not tried it, but you should be able to add a MIDI track, route it to the Helix and use it to send the CC. From memory here, so might be missing something, but this is roughly how to do it I think ... Create the MIDI track and add a MIDI event to it (Draw tool) Double click the event to open the MIDI editor Add a new controller lane -it'll default to velocity. Click where it says "velocity" and it'll give you a list of MIDI CC and other control types. 69 probably isn't listed but I there's an option to add it, I think it's in setup on the dropdown menu. Select CC69, add it to the list the go back and select it. Use Draw to add the CC events and you should be able to add/change the snapshots Mike Thanks for the explanation. I've already setup a midi track but I missed the step with the controler lane. I'll try it out when I'm at home Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 26, 2016 Author Share Posted July 26, 2016 Adding new controller lane worked - thanks. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted July 28, 2016 Share Posted July 28, 2016 Helix 2.0 also has a new MIDI Recall display in case you're not sure which MIDI message to use for recalling the current setlist, preset, or snapshot: Press the PRESETS encoder. Above Knob 2 you'll see gray text: The top line is the MIDI CC32 value for recalling the current setlist (000-007) The middle line is the MIDI PC value for recalling the current preset (000-127) The bottom line is the MIDI CC69 value for recalling the current snapshot (000-007) This has nothing to do with how to send that message from a DAW like Cubase, but at least you won't have to dig into Helix's manual. Quote Link to comment Share on other sites More sharing options...
regalpierot Posted July 28, 2016 Share Posted July 28, 2016 Wayish off topic, but seeing you write about recalling setlists reminded me. I have searched the manual in vain, and am probably missing something super simple, but is there a way to change setlists using the footswitches. To date I've had to reach down, press 'Presets' and then use the joystick to navigate left and down\up through setlists. And yes, I typically get that the usual workflow would be to have a single setlist for a gig or session but I do have some setlists logically broken down (Variax, Delaune etc) and when we are writing music I like to navigate through different ones to look for a tone I might alter and use....so would be handy for me. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 28, 2016 Share Posted July 28, 2016 .. is there a way to change setlists using the footswitches. ..... No. You have to do it using the Presets button and joystick, or the editor. Quote Link to comment Share on other sites More sharing options...
Dshow Posted July 29, 2016 Author Share Posted July 29, 2016 Helix 2.0 also has a new MIDI Recall display in case you're not sure which MIDI message to use for recalling the current setlist, preset, or snapshot: Press the PRESETS encoder. Above Knob 2 you'll see gray text: The top line is the MIDI CC32 value for recalling the current setlist (000-007) The middle line is the MIDI PC value for recalling the current preset (000-127) The bottom line is the MIDI CC69 value for recalling the current snapshot (000-007) This has nothing to do with how to send that message from a DAW like Cubase, but at least you won't have to dig into Helix's manual. Thanks! I've already read this in the manual - it's great Quote Link to comment Share on other sites More sharing options...
SebaPesciarellli Posted April 29, 2023 Share Posted April 29, 2023 I have the same problem. Helix waits for signals via cc69 to change values between 0-7 to change snapshots. The problem is that in Cubase, when you try to send different values through cc69, it only allows you to send 2 different ones: 0 or 127. This is because the cc69 is used to know if a pedal like "sustain" is depressed or not . No intermediate values. How to solve this? Can the parameter be changed in Helix, so that Helix would expect signals on a different cc? Quote Link to comment Share on other sites More sharing options...
kylotan Posted May 1, 2023 Share Posted May 1, 2023 This is something you will be able to fix within Cubase, as there's no reason why CC 69 would be limited to just those 2 values. Quote Link to comment Share on other sites More sharing options...
