ajfkeith Posted November 14, 2016 Share Posted November 14, 2016 I'm curious what is actually happening if my Helix is set up with a single input (in my case Variax VDI) into a preset where both DSPs are configured to take input from this device in parallel (e.g both set to "Multi"). Let's say on Path 1 I use a clean amp and on path 2 a crunchy one. Is this signal from the guitar shared/split in some way, or have I effectively created the equivalent of two identical guitars feeding two completely separate rigs? I'm trying to understand if this is the same as splitting a single path (Y or X/Y split) or not? Even if it is the same I suppose I could at least take advantage of additional DSP resources by using both inputs from the one source. Quote Link to comment Share on other sites More sharing options...
tommasoferrarese Posted November 14, 2016 Share Posted November 14, 2016 You split it. Like identical guitars played by identical players, in two separate channels. If you want a single path, you output path A to path B Quote Link to comment Share on other sites More sharing options...
hideout Posted November 14, 2016 Share Posted November 14, 2016 Look at it as using a virtual "Y" cable going to two different, or even the same rigs. Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted November 14, 2016 Author Share Posted November 14, 2016 Thanks for the replies. So is it fair to way there's no real difference between doing this and just using a Y Block on the Helix where one signal chain stays on Path 1A and the other (1B) is pushed to Path 2 at the output block? Well...other than if I do the former I can use a gate on one path (fuzz) and no gate on the other (clean). Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 14, 2016 Share Posted November 14, 2016 I made a patch where I have 3 different amps going into one cabinet, and can use all three at the same time, or any one or 2. Using multiple paths from one source gives you that kind of flexibility.A clean and a dirty amp at the same time is kinda cool. Into the same cabinet is impossible in the real world, but possible with Helix. 1 Quote Link to comment Share on other sites More sharing options...
spikey Posted November 15, 2016 Share Posted November 15, 2016 A clean and a dirty amp at the same time is kinda cool. Into the same cabinet is impossible in the real world, but possible with Helix. Well...., my 1960a is a "stereo" cabinet Hamm :P Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 15, 2016 Share Posted November 15, 2016 Well...., my 1960a is a "stereo" cabinet Hamm :P I've done this with similar cabs, but miking them is a pain in the rump. Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted November 15, 2016 Author Share Posted November 15, 2016 I made a patch where I have 3 different amps going into one cabinet, and can use all three at the same time, or any one or 2. Using multiple paths from one source gives you that kind of flexibility. A clean and a dirty amp at the same time is kinda cool. Into the same cabinet is impossible in the real world, but possible with Helix. Super cool. Thanks Peter. Quote Link to comment Share on other sites More sharing options...
