rickthestick Posted December 6, 2016 Share Posted December 6, 2016 The recommended fix worked, ...for a couple weeks but tonight it reared it's ugly head again out of nowhere. Has anyone else had it show up again after the workaround? I wouldn't want to deal with this at a gig! We need a permanent fix to address this issue. Hope it's coming soon... Quote Link to comment Share on other sites More sharing options...
kensington Posted December 6, 2016 Share Posted December 6, 2016 Hm. As long as I stay away from old patches, I'm fine. But if I choose an old patch and use the snapshots, and go back to my new patches, it's back. Are you sure you are not doing the same?I'm sure they have a fix for it when the new year comes around. In the meantime the fix is easy and works...for me:) Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted December 6, 2016 Share Posted December 6, 2016 I witnessed this very thing on Fulcrum's floor Helix - he had gone through all of them and applied the workaround fix, and all had been working fine. Then all of a sudden he was telling me that they had reverted. I think at the time he said he was changing the bank switch mode (holding both down for a moment) when he noted it right after. Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 6, 2016 Share Posted December 6, 2016 I believe a patch will be coming shortly, so hold tight. One way to workaround it permanently, and I realize it simply may not be acceptable to some people, is to use an external expression pedal for EXP2. If you have a pedal available to you, that would be my suggestion until that patch arrives. Quote Link to comment Share on other sites More sharing options...
rickthestick Posted December 6, 2016 Author Share Posted December 6, 2016 The fix is easy for most but I have my Helix mounted in a custom case so it's a bit more difficult to get to the jack. The second pedal is not an option as I'm gigging a lot and it would have to be plugged in and out at each gig. As I stated above, not easy to do. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted December 6, 2016 Share Posted December 6, 2016 I believe a patch will be coming shortly, so hold tight. One way to workaround it permanently, and I realize it simply may not be acceptable to some people, is to use an external expression pedal for EXP2. If you have a pedal available to you, that would be my suggestion until that patch arrives. I am using an external for EXP2 until a fix comes out. Saves a lot of time rather than doing the temporary fix. Quote Link to comment Share on other sites More sharing options...
