DirtFarmer Posted January 12, 2017 Share Posted January 12, 2017 Hey guys! I recently picked up a Helix rack, WHOOT YAA MEEE!!! I also picked up a Korg rack tuner. But I don't want to have my signal colored by the tuner, it's not true bypass. But I very much like having a tuner always on. For reference, I'm referring to DSP as the two different channels in the Helix. The TOP and Bottom paths. Sorry if that is incorrect. My thought is it should be simple enough create a tuner out path. The easy way using the second/bottom DSP with (guitar in -> 1/4" out) into the Korg. So there would always be a dry signal going straight into the tuner. But that forces me to give up one DSP just for tuning. Are there other ways to get a dry signal out without using one of the DSP. Not really looking to get add a third item like a buffered ABY box, hoping to achieve this in Helix. BTW, I love Helix... such a cool device. 1 Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted January 12, 2017 Share Posted January 12, 2017 If the Korg doesn't always have to be active, you can assign Helix's tuner to feed your Korg instead: Press and hold TAP/TUNER. Turn Knob 2 (Output) to select Send 1/2 (or Send 3/4). Connect Send 1 or 2 (or 3 or 4) to your Korg. Now anytime you engage Helix's tuner, it'll send your signal to your Korg. If the Korg does have to always be active: Add a Send/Return > Send 1 (or 2, 3, or 4) block as the first item on Path 1A. Connect Send 1 (or 2, 3, or 4) to your Korg. 1 Quote Link to comment Share on other sites More sharing options...
DirtFarmer Posted January 12, 2017 Author Share Posted January 12, 2017 Awesome! Thank you for the tips!!! you rock Quote Link to comment Share on other sites More sharing options...
EdwinV Posted January 12, 2017 Share Posted January 12, 2017 Hi, You could do this in multiple ways and also depends on how you are using your Helix. One way would be to create parallel paths (1A and 1B), split them at the beginning of your signal path and have path 1A routed to your normal output. You can configure the output of path 1B e.g. to send1/2 and send that to your tuner. Hope that helps! Quote Link to comment Share on other sites More sharing options...
DirtFarmer Posted January 12, 2017 Author Share Posted January 12, 2017 Ya, reading both of the responses it really just shows how new I am to Helix and amp modeling. I love it and have some awesome tones already but it seems like this is going to be an ongoing learning process. Quote Link to comment Share on other sites More sharing options...
ricstudioc Posted January 12, 2017 Share Posted January 12, 2017 I love it and have some awesome tones already but it seems like this is going to be an ongoing learning process. Heh heh - yah, that it is, but the graphical interface will be second nature in no time. Enjoy yerself, welcome to the club! ... and yeah, just toss a Send in wherever. Done. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 12, 2017 Share Posted January 12, 2017 Helix's "patch bay" flexibility is exceptionally easy to get the hang of! And, often a lot easier than physically plugging and unplugging cables. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted January 12, 2017 Share Posted January 12, 2017 Output is already going to 1/4" and XLR outputs. If you are not already using all of those, just route one through your tuner and it will be active all the time. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 12, 2017 Share Posted January 12, 2017 Which rack tuner? It might not be as good as the one in Helix, just' saying'... Quote Link to comment Share on other sites More sharing options...
DirtFarmer Posted January 12, 2017 Author Share Posted January 12, 2017 Which rack tuner? It might not be as good as the one in Helix, just' saying'... Its the Korg pitchblack rack tuner, one of the newer versions. It's not that I need it to be very accurate, I just prefer to have a tuner on when I play. Its a preference thing, not that I need it, just something I like. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 12, 2017 Share Posted January 12, 2017 Its the Korg pitchblack rack tuner, one of the newer versions. It's not that I need it to be very accurate, I just prefer to have a tuner on when I play. Its a preference thing, not that I need it, just something I like. With the rack, you can have the "buffered guitar out" go to it and have no other need of setting anything up. I sometimes think I'm going to hook up my strobostomp this way, but fact is the tuner on Helix works great for me. Quote Link to comment Share on other sites More sharing options...
