JLondon Posted March 1, 2017 Share Posted March 1, 2017 I typically use Helix with L6 Link and Stagesource speakers and have never had a problem that wasn't due to user error. I thought I'd try a simple setup going straight into front of an amp using Helix 1/4 out (left/mono) jack. I've got input set to guitar and output set to 1/4 out and global set to instrument level. All I'm getting is a lot of noise and a barely detectable signal from guitar. Yes, I've checked the cables, guitar, and amp. Am I missing something? It appears as though something is wrong with the 1/4 out jack. I tried the 4 cable method when I first got the Helix (numerous updates ago) and it worked fine. I haven't tried it this time though. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted March 1, 2017 Share Posted March 1, 2017 the quarter inch out to the stagesource speaker work fine? Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted March 1, 2017 Share Posted March 1, 2017 Some maybe obvious things we all overlook sometimes. Using a ts cable? Volume knob on helix? Try different cable? Does same cable work with guitar direct to amp? Open a blank "new preset" and try. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 1, 2017 Share Posted March 1, 2017 Try setting the Output Block to Multi. Try defining an FX Send Block assigned to any one of the four FX Sends and set the Global I/0 Level for that FX Send to Instrument Level. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 1, 2017 Share Posted March 1, 2017 ^Yes, check that the output block in the preset is set to "multi". Quote Link to comment Share on other sites More sharing options...
