redcloud Posted May 23, 2017 Share Posted May 23, 2017 Hi! I'm wondering if anybody has tried to add a metal spring to the built-in expression pedal. Could work? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 24, 2017 Share Posted May 24, 2017 Why? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 24, 2017 Share Posted May 24, 2017 You could add a corkscrew, an ankle holster for a snub nose .38, and a potted ficus if you want...the question would be, for what possible purpose? Quote Link to comment Share on other sites More sharing options...
duncann Posted May 24, 2017 Share Posted May 24, 2017 He probably wants the pedal to automatically return to the heel position at the moment when he decides not to use it. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 24, 2017 Share Posted May 24, 2017 Hmmm external exp pedal, loosen the pivot bolt and reverse the 0-100 settings? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 24, 2017 Share Posted May 24, 2017 He probably wants the pedal to automatically return to the heel position at the moment when he decides not to use it. Does such a thing exists anywhere else in nature? Never seen one... Quote Link to comment Share on other sites More sharing options...
duncann Posted May 24, 2017 Share Posted May 24, 2017 Does such a thing exists anywhere else in nature? Never seen one... I think Mission Engineering makes some sort of spring loaded pedal. Quote Link to comment Share on other sites More sharing options...
redcloud Posted May 28, 2017 Author Share Posted May 28, 2017 Usage example https://youtu.be/kJaixIfmSbc?t=1m1s 1 Quote Link to comment Share on other sites More sharing options...
redcloud Posted May 28, 2017 Author Share Posted May 28, 2017 Does such a thing exists anywhere else in nature? Never seen one... So shut up and learn from others Quote Link to comment Share on other sites More sharing options...
redcloud Posted May 28, 2017 Author Share Posted May 28, 2017 Who's talking about a "wah" pedal? Quote Link to comment Share on other sites More sharing options...
redcloud Posted May 28, 2017 Author Share Posted May 28, 2017 1 more https://youtu.be/Bw6PNyN9-JY?t=2m44s Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 28, 2017 Share Posted May 28, 2017 So shut up and learn from others Yes sir! Ever so sorry sir! I will be sure to clear everything with you first from now on. Quote Link to comment Share on other sites More sharing options...
redcloud Posted June 3, 2017 Author Share Posted June 3, 2017 So I did it! Bought a compression spring 22 millimiters diameter, 50 mm in length and mounted this way It works like a charm! Quote Link to comment Share on other sites More sharing options...
bjnette Posted June 3, 2017 Share Posted June 3, 2017 Clever! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 3, 2017 Share Posted June 3, 2017 And I am going to laugh when you try stomping on the thing in your mom's basement and you end up breaking your $500 unit trying to do the same stage showboating a millionaire does with a $30 pedal that he gets for free. Fyi, Vai didn't have that spring loaded pedal when he was recording it. Quote Link to comment Share on other sites More sharing options...
redcloud Posted June 4, 2017 Author Share Posted June 4, 2017 And I am going to laugh when you try stomping on the thing in your mom's basement and you end up breaking your $500 unit trying to do the same stage showboating a millionaire does with a $30 pedal that he gets for free. Fyi, Vai didn't have that spring loaded pedal when he was recording it. I'm not even trying to imitate Vai. IMHO this way the work you do using wah (or volume) is exactly a half; it's just a mechanical aid that *should* not stress that much the structure of the pedal: the spring is calibrated for 2.5 Kg weight. Quote Link to comment Share on other sites More sharing options...
