More versatile routing as audio interface
mingyi
Sorry for my poor English
Helix has so many physical inputs and outs,but its routing options are far too limited, unlike other professional audio interfaces which can basically route any input to any output 。Now if I want to use helix to play programmed samples or to create a monitor mix to feed my IEM,it is impossible to do that without taking up a processing path(but we have two guitarists each take up a path ),and the routing would change if you switch presets。I wish helix could come up with a dedicate routing mixer section,routing statues can be global regardless of preset change,so we can take full advantage of these physical inputs and outs。This functionality would allow us to ditch our audio interfaces and really simplify our live rigs!
I also put this in ideascale
https://line6.ideascale.com/a/idea-v2/911447
Exactly what routing scheme are you trying to accomplish?
Keep in mind, the Helix is a guitar/bass rig and is not intended to be an all encompassing mixer/router for the studio/live environment. All of those inputs and outputs are designed for instruments, effects, and connecting to mixers/amps/DAWs.
