moohman Posted September 25, 2017 Share Posted September 25, 2017 Hi, I just bought used POD XT with broken usb port. I've tried to authorize connecting via midi ports, but license manager does not detect the device. Can I authorize it through the midi at all? 1 Quote Link to comment Share on other sites More sharing options...
RMAlonso Posted October 10, 2017 Share Posted October 10, 2017 Hi, Do you solved your problem? I have the same problem. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 10, 2017 Share Posted October 10, 2017 Can Monkey see it? Quote Link to comment Share on other sites More sharing options...
RMAlonso Posted October 10, 2017 Share Posted October 10, 2017 Is not found in Monkey. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 10, 2017 Share Posted October 10, 2017 What type of midi cables are you using? Quote Link to comment Share on other sites More sharing options...
RMAlonso Posted October 11, 2017 Share Posted October 11, 2017 It's a USB Cable. Atacched you find the message error: IMPORTANT!: The PODxt Live you are connecting to is not valid Line 6 hardware. Please inform Line 6 Customer Support about this message to receive further instructions. Could you help me with it? Quote Link to comment Share on other sites More sharing options...
RMAlonso Posted October 11, 2017 Share Posted October 11, 2017 There was an error communicating with your device. If it is a USB device, try disconnecting then reconnecting the USB cable. Error: (Code 8000710B) Hardware is not valid. Please contact Line 6 customer service immediately with this error. Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 11, 2017 Share Posted October 11, 2017 To use midi you need to use a midi/usb cable like the M-Audio Uno. Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted October 12, 2017 Share Posted October 12, 2017 To use midi you need to use a midi/usb cable like the M-Audio Uno. This is correct. You must use a decent quality cable - cheap cables often do not transmit SysEx data, which is what you need for the software to see the Pod. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 12, 2017 Share Posted October 12, 2017 Long time no see Mr_Arkadin!! Quote Link to comment Share on other sites More sharing options...
