themetallikid Posted November 24, 2017 Share Posted November 24, 2017 Curious if anyone has created a good Raygun sound....we recently added Rebel Yell back to the list, and previous rigs (Fractal, Boss) I've been able to create a good ray gun using either vibes or delay settings. I don't pretend to understand how the delay makes a good raygun sound.....but it was the best one I've tried. So....any good rayguns out there? Or other fun strange sounds. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 24, 2017 Share Posted November 24, 2017 I have a separate expression pedal aside from the internal one on the floor Helix. Use either the Cosmos Echo or the Transistor Tape delays. Put which ever one you choose before a Marshall amp. Assign one expression pedal to the Feedback and one to the Delay time. Use both feet and enjoy the sonic fun. This is essentially what Tom Sholz of Boston does with his Echo unit to turn it into his "Hyperspace" pedal. You will eventually need to adjust the min and max amounts for the pedals (like reversing the min and max for the delay i.e. make the min the max amount and the max the min amount) but this will give you an idea of what this does. 1 Quote Link to comment Share on other sites More sharing options...
Dshow Posted November 25, 2017 Share Posted November 25, 2017 I think you need a ray gun for that ;-) https://youtu.be/OSMZMcQz0NE?t=39s Quote Link to comment Share on other sites More sharing options...
saks Posted November 26, 2017 Share Posted November 26, 2017 I have a separate expression pedal aside from the internal one on the floor Helix. Use either the Cosmos Echo or the Transistor Tape delays. Put which ever one you choose before a Marshall amp. Assign one expression pedal to the Feedback and one to the Delay time. Use both feet and enjoy the sonic fun. This is essentially what Tom Sholz of Boston does with his Echo unit to turn it into his "Hyperspace" pedal. You will eventually need to adjust the min and max amounts for the pedals (like reversing the min and max for the delay i.e. make the min the max amount and the max the min amount) but this will give you an idea of what this does. very cool! I don't have a second expression pedal so assigned the feedback to the tone knob on my variax, works great. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 27, 2017 Share Posted November 27, 2017 very cool! I don't have a second expression pedal so assigned the feedback to the tone knob on my variax, works great. That's a great idea. I keep forgetting about that option. Using two feet doesn't work too well. I was going to maybe come up with some kind of contraption like what Mr Scholz did but I think this will work just as well with much less thinking and effort. Quote Link to comment Share on other sites More sharing options...
saks Posted November 27, 2017 Share Posted November 27, 2017 That's a great idea. I keep forgetting about that option. Using two feet doesn't work too well. I was going to maybe come up with some kind of contraption like what Mr Scholz did but I think this will work just as well with much less thinking and effort. at my age using one foot is a challenge ;) Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 27, 2017 Share Posted November 27, 2017 at my age using one foot is a challenge ;) Amen! Quote Link to comment Share on other sites More sharing options...
Embo20910 Posted November 27, 2017 Share Posted November 27, 2017 Any chance you can use the control voltage outputs of a theremin in the EXP2 and EXP3 inputs? You could control all kinds of stuff just by moving around. But I’m guessing plugging a CV into the EXP might be a bad idea. Quote Link to comment Share on other sites More sharing options...
tedulrich Posted November 28, 2017 Share Posted November 28, 2017 Any chance you can use the control voltage outputs of a theremin in the EXP2 and EXP3 inputs? You could control all kinds of stuff just by moving around. But I’m guessing plugging a CV into the EXP might be a bad idea. I do it all the time with an EHX 8-Step Program into EXP3. The depth has to be set to "5" but it works just fine. Since the 8-Step doesn't output over MIDI, I also use the Helix to assign it via EXP3 to MIDI CCs to control outboard gear. Quote Link to comment Share on other sites More sharing options...
