srmd22 Posted February 2, 2018 Share Posted February 2, 2018 I see how to save a preset into a new location, and I can swap presets the following way, but it is arduous: Save preset A into an empty location; Save preset B into preset A's old location, over-writing it; Save preset A from it's temporary place into B's "old" location, over-writing it. But is there a way to just swap A<->B directly? I found swapping stomp footswitches and snapshots in the manual, but not presets - maybe can't be done? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 2, 2018 Share Posted February 2, 2018 I see how to save a preset into a new location, and I can swap presets the following way, but it is arduous: Save preset A into an empty location; Save preset B into preset A's old location, over-writing it; Save preset A from it's temporary place into B's "old" location, over-writing it. But is there a way to just swap A<->B directly? I found swapping stomp footswitches and snapshots in the manual, but not presets - maybe can't be done? There is no way to swap presets right now. You could probably edit the backup files directly and pull it off but at that point you might as well cut and paste. Quote Link to comment Share on other sites More sharing options...
kylotan Posted February 2, 2018 Share Posted February 2, 2018 From the Preset selection screen (the one with setlists on the left and presets on the right), select the preset you want to move, then turn the third of the six dials to reorder it in the list. 5 Quote Link to comment Share on other sites More sharing options...
zooey Posted February 2, 2018 Share Posted February 2, 2018 kylotan is right, there is a simple and quick way, right on the Helix itself. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 2, 2018 Share Posted February 2, 2018 You can also drag-and-drop or cut-and-paste your presets using the HX Edit application on your computer. Quote Link to comment Share on other sites More sharing options...
srmd22 Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks - I have used that feature, but thought it was limited to swapping presets within a set list. What if you want to swap a preset between two separate set lists? Quote Link to comment Share on other sites More sharing options...
srmd22 Posted February 2, 2018 Author Share Posted February 2, 2018 You can also drag-and-drop or cut-and-paste your presets using the HX Edit application on your computer. I have moved around a couple like this, but I haven't dropped one on top of another - do you get an option to swap versus replace if you do that? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 2, 2018 Share Posted February 2, 2018 I don't know about the unit itself but if you right click on the preset's name in HX Edit, you can COPY the preset, move to the setlist you want, right click where you want it and there will be a PASTE option. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 2, 2018 Share Posted February 2, 2018 Thanks - I have used that feature, but thought it was limited to swapping presets within a set list. What if you want to swap a preset between two separate set lists? You can certainly cut-and-paste between set lists. I do this all of the time when I copy a built-in template or preset over to one of my set lists. Quote Link to comment Share on other sites More sharing options...
srmd22 Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks, I get the cut and paste option - just wondering if you have to over-write what you are pasting to, if there is already a preset in that slot, or if you can actually swap the two. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 2, 2018 Share Posted February 2, 2018 Thanks, I get the cut and paste option - just wondering if you have to over-write what you are pasting to, if there is already a preset in that slot, or if you can actually swap the two. When going between different setlists, it replaces it. You lose the one that was in the slot. When you are in the same setlist, it moves all of the other presets down one slot. Quote Link to comment Share on other sites More sharing options...
srmd22 Posted February 2, 2018 Author Share Posted February 2, 2018 When going between different setlists, it replaces it. You lose the one that was in the slot. When you are in the same setlist, it moves all of the other presets down one slot. I see thanks. What happens to the set list that you move it from? Does it have one less preset? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 2, 2018 Share Posted February 2, 2018 From the Preset selection screen (the one with setlists on the left and presets on the right), select the preset you want to move, then turn the third of the six dials to reorder it in the list. Outstanding, thanks for this info kylotan! I stand corrected, was not even aware of this feature as I tend to do all of my setlist reorganization through the Editor. Looks like this would be a nice feature to add to the Editor (assuming it is not already there, don't want to be incorrect twice). I usually preface all of my statements about these kinds of matters with "As far as I am aware of", reminder to self, keep doing that. ;) Quote Link to comment Share on other sites More sharing options...
supertonic_jack Posted May 13, 2018 Share Posted May 13, 2018 There is a quicker way ;) hold SHIFT while dragging and dropping. 1 Quote Link to comment Share on other sites More sharing options...
jesuscares Posted May 15, 2018 Share Posted May 15, 2018 On 2/2/2018 at 4:37 AM, kylotan said: From the Preset selection screen (the one with setlists on the left and presets on the right), select the preset you want to move, then turn the third of the six dials to reorder it in the list. Great ! Does the moved location get saved by default? Quote Link to comment Share on other sites More sharing options...
jesuscares Posted May 29, 2018 Share Posted May 29, 2018 On 5/13/2018 at 7:39 PM, jjgerb said: There is a quicker way ;) hold SHIFT while dragging and dropping. Does it swap (exchange) the tones while holding shift? Quote Link to comment Share on other sites More sharing options...
jesuscares Posted January 6, 2019 Share Posted January 6, 2019 Just checking if there are any improvements on the Swap question.Still hoping something would come up to make it an easy swap. Quote Link to comment Share on other sites More sharing options...
supertonic_jack Posted May 14, 2020 Share Posted May 14, 2020 On 5/14/2018 at 1:39 AM, supertonic_jack said: There is a quicker way ;) hold SHIFT while dragging and dropping. sorry for that! it was wrong information. The SHIFT swap worked on my old Spider 4 remote control software. For Helix (and Helix native?) it does NOT work unfortunately. Or were there any changes in the meantime? 2 years later....... Quote Link to comment Share on other sites More sharing options...
Mutonium Posted June 8, 2022 Share Posted June 8, 2022 On 5/14/2020 at 11:57 AM, supertonic_jack said: sorry for that! it was wrong information. The SHIFT swap worked on my old Spider 4 remote control software. For Helix (and Helix native?) it does NOT work unfortunately. Or were there any changes in the meantime? 2 years later....... In the meantime... 2 years later... It now works in HX Edit! Thank you for the old tip. It is such a time saver from trying to find an appropriate spot for temporarily holding a preset, scrolling back to the preset, copying the preset, scrolling back to the found spot, pasting the preset there, scrolling to the new preset, copying it, scrolling to the desired spot, pasting it, scrolling back to the temporary spot, copying that preset, scrolling back to the other spot, and pasting the preset. *Whew* ("In the meantime..." Spacehog!) 1 Quote Link to comment Share on other sites More sharing options...
jesuscares Posted June 15 Share Posted June 15 IN 2025 I'm still having trouble swapping presets on my Mac.I dont see a right click swap option at all. Here is what AI says but I dont see it!: To swap presets in HX Edit, follow these steps: Open HX Edit: Launch the HX Edit software on your computer. Select the Presets: Navigate to the preset you want to swap. You can do this by clicking on the preset name in the preset list. Use the Swap Function: Right-click on the preset you want to swap with another preset. Select the "Swap" option from the context menu. Choose the Target Preset: Click on the preset you want to swap with. The two presets will exchange places in the list. Save Changes: Don’t forget to save your changes to ensure the swap is permanent. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted June 16 Share Posted June 16 On 6/15/2025 at 9:26 PM, jesuscares said: Here is what AI says Um… why wasting your precious time with Artificial Idiocy when all you need to do is to select the Help menu → HX Edit Application Pilot's Guide which opens the built-in PDF manual, then navigate to the section titled "Renaming, Reordering, Copying, and Pasting Presets" which happens to be on page 14. ;) 1 Quote Link to comment Share on other sites More sharing options...
