flanger68 Posted March 28, 2018 Share Posted March 28, 2018 Hello, i find great that the M20d can record the full band while playing...the sound quality is excellent too. I noticed though, that the level of the recorded file is extremely low...it sounds loud when played back on the M20d itself ...but when imported into a computer, for example into Audacity, you can see the waveform is a very thin line....and playes back extremely soft. You need to normalize the audio to get to a "normal" volume. Is there anything to do on the M20d to set the recording level higher than this ? Many thanks if anyone has noticed this before... Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 28, 2018 Share Posted March 28, 2018 The signal that is recorded is tapped off of the DAC, after the input trim, so turning up the trim would increase the levels, but you may not want to do that. It's really not that big of a deal if the levels are coming in low. You can raise them easily after the fact by normalizing them, like you said. Just don't normalize them to 0dB. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted March 29, 2018 Share Posted March 29, 2018 One thing we do is knock our PA amp levels down so the master can run around -6 db or so...How much depends on the room...This makes the Main Mix track a bit more nominal venue to venue... Quote Link to comment Share on other sites More sharing options...
flanger68 Posted March 30, 2018 Author Share Posted March 30, 2018 Thanks to both of you for your suggestions! Quote Link to comment Share on other sites More sharing options...
