chrisblythenz Posted May 18, 2018 Share Posted May 18, 2018 Hi all I've FINALLY got a midi cable to connect to the DT25 and updated v2 firmware. DTedit connects fine and I can make changes and it changes on the amp. What I can't figure out is that there are 2 preamp sets per channel making 16 possible presets, but i can't see how this works. There doesnt seem to be a manual anywhere to explain this. So, question is, how do I access all 16 amps from my amp when I'm not connected to DTedit? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 18, 2018 Share Posted May 18, 2018 If you got DT Edit from GitHub, then it is a 3rd party application, so there won't be any documentation for that here on the official Line 6 site pages, since the application is not our product. If it's not in our Downloads page or online Manuals page, then you would need to go to the source site where you got the application and get a manual from there. Quote Link to comment Share on other sites More sharing options...
chrisblythenz Posted May 18, 2018 Author Share Posted May 18, 2018 Ok, dumb question then! How do I configure the dt25 without DTEdit? I can’t see anything in the pilots guide. Is it all by midi via an HD500 or similar? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 21, 2018 Share Posted May 21, 2018 There's nothing in the Pilot's guide because it's a 3rd party product, not a Line 6 application, and so it is not a Line 6 supported product. You will nee to go to the site where you got the application, and get whatever guide or manual they have from them. Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted May 27, 2018 Share Posted May 27, 2018 On 5/18/2018 at 12:07 AM, chrisblythenz said: Hi all I've FINALLY got a midi cable to connect to the DT25 and updated v2 firmware. DTedit connects fine and I can make changes and it changes on the amp. What I can't figure out is that there are 2 preamp sets per channel making 16 possible presets, but i can't see how this works. There doesnt seem to be a manual anywhere to explain this. So, question is, how do I access all 16 amps from my amp when I'm not connected to DTedit? You'd only be able to access 4 amps when not connected to DTedit using the I, II, III, IV switch. What you program in DTedit for these will correlate once you've applied the programming. Hope this helps. Jd Quote Link to comment Share on other sites More sharing options...
oscarguitar Posted May 27, 2018 Share Posted May 27, 2018 You can get 8 Amps. 4 on channel A and 4 on channel B using DTEdit Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted May 28, 2018 Share Posted May 28, 2018 20 hours ago, oscarguitar said: You can get 8 Amps. 4 on channel A and 4 on channel B using DTEdit You are correct. I forgot about the B switch that doubles it. Jd Quote Link to comment Share on other sites More sharing options...
chrisblythenz Posted May 28, 2018 Author Share Posted May 28, 2018 Thanks guys. I’m curious though, without DTedit is the only way to access the different preamps by using a midi controller? I have an HD500 so have the preamps in that anyway, so wondering what people who don’t have a Pod will do to access the new amps Quote Link to comment Share on other sites More sharing options...
steved61 Posted June 20, 2018 Share Posted June 20, 2018 Quote wondering what people who don’t have a Pod will do to access the new amps They can't unless they use DT EDIT and a midi interface to change them. Not sure why Line 6 added all those extra preamps - I'm guessing it's more to do with syncing with the HD Pod than letting people in there to change them themselves Quote Link to comment Share on other sites More sharing options...
Brazzy Posted June 21, 2018 Share Posted June 21, 2018 On 5/28/2018 at 2:46 PM, chrisblythenz said: Thanks guys. I’m curious though, without DTedit is the only way to access the different preamps by using a midi controller? I have an HD500 so have the preamps in that anyway, so wondering what people who don’t have a Pod will do to access the new amps There was an application created by a third party years ago and was sold in the Apple App Store which was for an iPhone or iPad and with the correct midi to iPad/iPhone adapter connected one could control the internal functions. I think it was called DTCustomizer but I'm not sure it's available to buy anymore. Also there was an app called (I think) MIDI Memo and it could record all of the changes one made to all midi devices connected to the amp (like it's own network). After recording all of ones moves they could be played back and the musician could play in sync with the played back recording of 'the changes' he or she wouldn't even have to think about pressing any buttons (pedal buttons) unless a pause was in order. There was also some midi controllers with pedal buttons made that could be programmed, I forget the name brand at the moment. You could do a google search and probably find the company. Quote Link to comment Share on other sites More sharing options...
TravisaurusRex Posted August 13, 2018 Share Posted August 13, 2018 chrisblythenz - What midi cable/interface did you use? I cannot get one to work with mine via PC or Mac. Quote Link to comment Share on other sites More sharing options...
chrisblythenz Posted August 14, 2018 Author Share Posted August 14, 2018 Hi. I think I used a midi sport uno 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 14, 2018 Share Posted August 14, 2018 We use Uno here too. And as always,... don't have any USB hubs connected when connecting Line 6 product to a computer. 1 Quote Link to comment Share on other sites More sharing options...
