Trotsky Posted May 21, 2018 Share Posted May 21, 2018 Hi everyone. New to forum person here with a helix LT hummer . I’ve had the Helix since August 17. Very pleased with it, however about 4 Weeks ago a nasty constant hum has developed. Before everyone starts bouncing back with ideas about guitar cables and everything else this is a strange one. I use it in 4 cable to my valve amp and don’t use any amp models. So, helix connected to amp with 4 cables or directly in to front of amp, connect the mains lead to the helix and the gruesome loud hum appears before the helix is even switched on!! Driving me nuts now as my last three gigs have not been a pleasurable experience ! Personally I think the helix is duff but any ideas out there guys ?? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 21, 2018 Share Posted May 21, 2018 What happens if you run the guitar straight into the amp with Helix removed from the equation completely? Is the hum still present? Any other gear/pedals involved? Quote Link to comment Share on other sites More sharing options...
Trotsky Posted May 21, 2018 Author Share Posted May 21, 2018 Guitar into amp is as quiet as a church mouse. Tried friends amp, same noise. I’ve removed all my other pedals etc from the equation. Quote Link to comment Share on other sites More sharing options...
patdixon Posted May 21, 2018 Share Posted May 21, 2018 1 hour ago, Trotsky said: before the helix is even switched on So with it on and hooked up in 4cm do you also have guitar sound with the hum, or just hum alone? What if you just go straight into the amp input from the left/mono 1/4 output jack, any difference? Quote Link to comment Share on other sites More sharing options...
Trotsky Posted May 21, 2018 Author Share Posted May 21, 2018 Have guitar sound output from helix with constant hum either direct in or 4cm. Obviously no guitar with helix switched off but the hum comes through the amp. Quote Link to comment Share on other sites More sharing options...
patdixon Posted May 21, 2018 Share Posted May 21, 2018 Since you've only had it since Aug I'd open up a service ticket. Quote Link to comment Share on other sites More sharing options...
Trotsky Posted May 21, 2018 Author Share Posted May 21, 2018 I’ve done that. No help. Looks like I’ll have to return it for repair/replacement...major grief ! Quote Link to comment Share on other sites More sharing options...
patdixon Posted May 21, 2018 Share Posted May 21, 2018 Sorry to hear that. I have an LT also but haven't experienced that on mine. Most of my problems are operator error :o) Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted May 21, 2018 Share Posted May 21, 2018 Have you tried to isolate the Helix ground. as only a test, find a 2 to 3 prong plug. Isolate helix, never use this on the tube amp chord!! Still noise? https://www.walmart.com/ip/Axis-Grounded-AC-Plug-Adapter-2-pack/21054194?wmlspartner=wlpa&selectedSellerId=1131&adid=22222222227015565217&wl0=&wl1=g&wl2=c&wl3=40880551952&wl4=pla-78808727072&wl5=9014416&wl6=&wl7=&wl8=&wl9=pla&wl10=112562428&wl11=online&wl12=21054194&wl13=&veh=sem Quote Link to comment Share on other sites More sharing options...
Trotsky Posted May 21, 2018 Author Share Posted May 21, 2018 That I haven’t tried. I have a take-apart iec connector that I can just remove the earth from. I’ll give it a try. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted May 22, 2018 Share Posted May 22, 2018 Return it and get HX Effects if you're happy with your amp but just want more options. HXFX is a pretty solid piece of kit. Other than the hardware issues that require sending it in for IC replacement at your expense, of course. I wish you luck! Quote Link to comment Share on other sites More sharing options...
Trotsky Posted May 22, 2018 Author Share Posted May 22, 2018 I’ll return the unit as it’s under warranty so I definitely won’t be paying a bean! Quote Link to comment Share on other sites More sharing options...
