lawrence_Arps Posted October 26, 2013 Share Posted October 26, 2013 This is my first attempt to record. I have a Sansdisk, SDHC 32 GB card, formatted to FAT32. The M20D will not recognise it at all. In record mode the lowest folder level shows my USB drive (for the media player) but not the SD card. Ive rebooted, reformatted etc... any ideas? Quote Link to comment Share on other sites More sharing options...
gordwait Posted October 26, 2013 Share Posted October 26, 2013 Try another card? If more than one known good card doesn't work, you may have a hardware problem with the m20d.. I've put a few different SD cards in, they all cause a little icon to appear on the stage.. 1 Quote Link to comment Share on other sites More sharing options...
lawrence_Arps Posted October 28, 2013 Author Share Posted October 28, 2013 Me again... So I have been able to use an oldish USB stick to run a playlist, but no other devices are recognized. When the SDcard is plugged in there is no reaction from the M20D..no icon and no access in the record menu. I tried a USB disc drive and got the same result. I haven't tried the PC connector at this point. I have V1.2 loaded, and all other functions are behaving. It's looking like a hardware fault of some kind....... Quote Link to comment Share on other sites More sharing options...
lawrence_Arps Posted October 28, 2013 Author Share Posted October 28, 2013 I see that I'm not the only one........I think I'll log this with Support.. Quote Link to comment Share on other sites More sharing options...
bassman24 Posted October 29, 2013 Share Posted October 29, 2013 Hi, 2 things: have you tried navigating to the root of the SD in order to see your Folders in the file explorer of the M20d (suggesting your SD Card will show up in the file explorer)? Have you tried another SD Card? Windows is very forgiving regarding to faulty cards, in opposite of other devices like cameras or in this case the M20D, if you can put in another card, which is also not recognized it´s most likely a hardware issue of the M20d. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted October 29, 2013 Share Posted October 29, 2013 +1 to Bassman24's comments. I think it's pretty common that if you don't navigate to the root of the SD card you can't get it to show up. I ran into that issue as did many others, it's just the way the M20d works. Quote Link to comment Share on other sites More sharing options...
brianj402002 Posted October 29, 2013 Share Posted October 29, 2013 Yes...happened to me as well...was a little confused at first but after getting to the root...all was good.. Let us know if this works for you lawrence_Arps Quote Link to comment Share on other sites More sharing options...
lawrence_Arps Posted October 30, 2013 Author Share Posted October 30, 2013 Hi yes Ive tried two cards and a USB Disc Drive. As I said in my opening post, it does not show up at all. No icon, no presence in the record folder navigation at all. Quote Link to comment Share on other sites More sharing options...
treewiz Posted February 16, 2014 Share Posted February 16, 2014 I'm having the same problem with my sd cards and usb sticks, what gives? Quote Link to comment Share on other sites More sharing options...
coupe Posted October 1, 2014 Share Posted October 1, 2014 I had the same problem. What helped me was format the SD card in my Panasonic Camera (in my PC it did not help). After inserting card in the camera it suggested to format the media card. ...and at works like before. Later I just deleted the extra folders the camera created after formatting (SD 32GB, Class 10). Quote Link to comment Share on other sites More sharing options...
hep3c Posted May 30, 2015 Share Posted May 30, 2015 I see many posts about issues with SD cards. I am having he same issue. Are there any other solutions? I have tried multiple cards, formatted to Fat 32, no card icon appears. Even on cards that I have used i nthe past. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted May 31, 2015 Share Posted May 31, 2015 In order to see the SD card you need to unplug any USB storage media. The system looks for the USB first and then for the SD. Sorry for the inconvenience. Quote Link to comment Share on other sites More sharing options...
joecaster Posted June 25, 2015 Share Posted June 25, 2015 Having the same problem (USB not showing in the recording screen), I think I found where the problem comes from. It came to my mind that it was happening because I created my setup from an existing one, then "saving as". So I recreated the same setup from scratch this time and now my USB is showing when I go in the recording screen. It looks like a bug happening when you "save as". I hope this helps others. 1 Quote Link to comment Share on other sites More sharing options...
IBenJamin Posted March 9, 2017 Share Posted March 9, 2017 Joecaster has the winning advice on SD card issues. I've noticed that scene availability changes whether you're in setup or performance modes. It was a pain to rebuild a scene I had working, but, the new one recognizes the card. This problem crashed my birthday jam, but, at least I have an answer. Also, the other big revelation is that recording is all about the Trim levels only. Pass these two tips along to save all headaches. Quote Link to comment Share on other sites More sharing options...
