HX Stomp as DSP Expansion
AZGuitar
Figured I would post this over here as well.
Here is what I am looking to do this weekend...HX Stomp as DSP Expansion...
I need to learn how to control on/off state of snaps in HXS from Helix command center via midi. If you are doing the same let me know here or pm me. Thanks and BTW, running HXS in stereo loop is absolutely amazing, now I need to fully integrate it and add a riser. Link to pic below
https://imgur.com/a/48Z700p
12 hours ago, DunedinDragon said:
I'll be curious to see if this exhibits any perceivable latency with the serial nature of the signal chain on complex signal chains using all three DSP chips.
No discernible latency at all. It works great.
I am now controlling on off states of effects in 3 snapshots via midi command center from Helix floor. I should be able to call the preset though as well correct? Once this is mapped from Helix floor, I am in Helix Heaven. Perter, do you know how? This functionality provides a side car with floor or any other midi capable device. An official Line 6 video would be awesome like the one created to show expression pedal setup.
All the MIDI commands and what they do to do this control from command center in Helix or LT or Rack are actually in the HX Stomp Manual, starting on p. 48. There might be a video out there, I don't know.
  • 3 years later...
  • 1 year later...
I'm doing this exact thing but with the Helix Rack. Not a lot of YouTube videos on how it was possible and how to hook it up till I opened the HX stomp Manuel and there it was with a illustration of wiring!  I got everything hooked up and midi talk to each other but as far as setting up what I need it to do through command center I'm lost. I had bought a midi maestro to run a looper pedal board but I couldn't  figure the damn thing out or it's android app! We're do I find the midi implementation charts for both devices? Is there even one to download? I figured out how to program hotkeys so I can stop/start armed tracks in studio one 6 was easy enough I'm just a  self proclaimed midiot when it comes to programming you'd think both devices are line 6 products it would be more plug and play if that's a thing.
