george_007 Posted January 15, 2019 Share Posted January 15, 2019 Hi team! Maybe this is a RTFM-question but I've always wondered what the result will be for a stereo preset if you connect the HX Stomp to a PA using only one cable (mono). Will you get only the left channel or will HX Stomp mix both channels and send them out as mono (in Main Output Left)? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 15, 2019 Share Posted January 15, 2019 The back of the stomp is clearly labelled OUTPUT LEFT/MONO. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 15, 2019 Share Posted January 15, 2019 It depends on how the physical output jack is labelled. If it says L/MONO then the stereo output is summed to mono when only the left jack is used.; if it just says L then the output is just the left side of the stereo image. 2 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 15, 2019 Share Posted January 15, 2019 3 hours ago, george_007 said: Hi team! Maybe this is a RTFM-question but I've always wondered what the result will be for a stereo preset if you connect the HX Stomp to a PA using only one cable (mono). Will you get only the left channel or will HX Stomp mix both channels and send them out as mono (in Main Output Left)? You are correct. This is a RTFM question. :) The HX Stomp will sum to mono a Stereo Preset whenever the Left/M Output Jack is used. Quote Link to comment Share on other sites More sharing options...
MilessDaviss Posted April 28, 2019 Share Posted April 28, 2019 Hi, I did the test. I set the preset with a stereo echo effect: - When listening with stereo headphones, the sound is reflected alternately in the left and right ear. You can calculate these reflections with 1,2 1,2 1,2 1,2 until it disappears. - Listening in LEFT (MONO) these are the same count of reflections: 1,2 1,2 1,2 1,2 by it is mono (sound is only in left ear); - When we put the second JACK into RIGHT OUTPUT, in the left channel is only 1,1,1,1,1, without 2,2,2,2,2; In conclusion, it is so physically done that by inserting only JACK in the LEFT (MONO) output you can hear both LEFT and RIGHT signal in the LEFT outpoot (MONO). Regards :) MilessDaviss Quote Link to comment Share on other sites More sharing options...
Sipuri Posted June 2, 2019 Share Posted June 2, 2019 How can I manage to have the left and right output jack set as mono each? I want connect one of them to the FoH/PA and the other one to my amp/rig... Is the signal always identical mono when no stereo effect (i. e. echon, modulation etc.) or special routing option has been used? Or do I need to use a block to set this (for each preset)? Thanks, Stefan Bavaria/Germany Quote Link to comment Share on other sites More sharing options...
