rampig59 Posted February 9, 2019 Share Posted February 9, 2019 I have not used my Relay G10 for several months and now when the system is plugged in for charging, the base flashes RED and so does the transmitter. After a few minutes the transmitter changes to a flashing GREEN and then goes back to flashing RED. If I remove the transmitter from the base, the base flashes WHITE and there is NO LIGHT on the transmitter. My software has the latest update installed. HELP!! 1 Quote Link to comment Share on other sites More sharing options...
Martin_G10 Posted March 14, 2019 Share Posted March 14, 2019 I have the same problem. My receiver flashes red and transmitter nothing at all. I was able to ise it ince only and then nothing. Quote Link to comment Share on other sites More sharing options...
tobiak Posted May 13, 2019 Share Posted May 13, 2019 Same problem me too .... RED the transmitter and Red or Nothing the receiver .... I tried also to update the firmware .. but nothing happen .. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 13, 2019 Share Posted May 13, 2019 This is just a guess, but somebody above mentioned the unit hadn't been used for several months...rechargeable batteries don't like that. Once they're dead long enough, they won't take a charge anymore. Try it with an old cell phone, tablet, ipod, etc.... or leave a vehicle sitting for an extended period without a trickle charger hooked up. At some point, there's no resurrecting them. 1 Quote Link to comment Share on other sites More sharing options...
tobiak Posted May 15, 2019 Share Posted May 15, 2019 Hi everyone .. I solved !! .. I have downgrade the transmitter to version 1.03, I previous updated to 1.04 .. now it's working again .... hope this work with you .. Quote Link to comment Share on other sites More sharing options...
tobiak Posted May 15, 2019 Share Posted May 15, 2019 Quote Link to comment Share on other sites More sharing options...
kirkieo Posted April 5, 2020 Share Posted April 5, 2020 thank you Tobiak i have the G10 and used both updates and it works Quote Link to comment Share on other sites More sharing options...
antuni Posted June 11, 2020 Share Posted June 11, 2020 On 5/15/2019 at 12:02 PM, tobiak said: Hi everyone .. I solved !! .. I have downgrade the transmitter to version 1.03, I previous updated to 1.04 .. now it's working again .... hope this work with you .. After I have updated, my transmitter stopped charging. Tried to revert back to the old firmware but it the software cannot detect my transmitter. Quote Link to comment Share on other sites More sharing options...
rmbentley Posted August 21, 2020 Share Posted August 21, 2020 I'm having the same problem as everyone above. I have a feeling my unit has just crapped out. I see that you can buy just the transmitter for $99 instead of the transmitter plus base for $169. Problem is, I don't know if the transmitter is bad and won't take a charge or the receiver base is bad and won't charge the transmitter. First question is how you can tell which piece is not working. Second question is whether a new transmitter will work with the old base. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 22, 2020 Share Posted August 22, 2020 20 hours ago, rmbentley said: First question is how you can tell which piece is not working. You can't. Quote Second question is whether a new transmitter will work with the old base. It should... but as you can see, the firmware "fix" for the battery overheating problem has caused various other problems for a number of us. Open a support ticket and see what they tell you. Personally, I'll only continue to use the two units I have with their diminished capacity and intermittent charging issues until the batteries crap out entirely, and then I'll be looking for something else. Quote Link to comment Share on other sites More sharing options...
PierM Posted August 25, 2020 Share Posted August 25, 2020 There is a firmware (1.06) for the G10T. Should take care of the flashing glitches. Not sure will improve the battery charge lifespan, but I'm happy they quickly reacted to a evident issue. "We have determined that certain Relay® G10T wireless transmitters with v1.05 firmware may not charge optimally within warm environments. The v1.06 firmware update addresses this issue to ensure correct charging behavior, as well as improving the response of the LED to more accurately display charging status. The v1.06 update also incorporates the important safety updates from the v1.05 firmware released in March of this year." Quote Link to comment Share on other sites More sharing options...
GaryDeFilippo Posted April 26, 2021 Share Posted April 26, 2021 Just got a new Line 6 Go Pod Wireless that had this same charging problem out of the box Quote Link to comment Share on other sites More sharing options...
Rooster-p Posted November 16, 2021 Share Posted November 16, 2021 I have both the g10 and the g10s. The g10 isn't 2 yrs old and when I put the transmitter in charger it will not stop blinking green. It used to so I know something is wrong. My guess is that it's not taking a full charge. The g10s has been a P.O.S. since I bought it. The g10 has better reception. You can't walk 10 feet away from the g10s without it dropping out. I have had no success in updating either unit so I have decided since line6 customer service doesn't seem to give a hoot I will throw both in the garbage and never buy another line6 product nor will I recommend them. Thank you very much. Quote Link to comment Share on other sites More sharing options...
Andy1175 Posted November 18, 2021 Share Posted November 18, 2021 Yep, me too. Had my G10 II and G10S for only five months, I use it just about every day but recently I've had trouble charging it and now it won't charge at all. Tried to update but the Line 6 updater does not recognise the G10 II presumably because it has no power, although it's plugged into the receiver/charger which is plugged into my Windows 10 PC. I've also tried charging it in my Yamaha THR30II but no joy there either. So that's £225 down the drain, or a load of agro getting it sorted, maybe. I should have known better really, line 6's reputation is as well documented as it is deserved. Quote Link to comment Share on other sites More sharing options...
danielseb93 Posted February 20, 2024 Share Posted February 20, 2024 I fix the problem charging the transmiter with external power supply. Write me to daniel.seb93@gmail.com for help Quote Link to comment Share on other sites More sharing options...
