Ux2 Not Picking Up Mic
Crank up Line 6 Monkey and update everything.  The disk that you installed from was obsolete 5 years ago.
Make sure you have POD Farm running.  Make sure that the input in POD Farm is set to Mic1.  Make sure you have the phantom power button pushed in on the UX2.  Make sure that you have the gain knob on top of the UX2 turned up.
Hi how can I change the input because I have the same problem?
  • 2 months later...
Hello. I recently bought a UX2 for myself, paired with a AT2035 Condensor microphone. I went though the standered procuedure of oputtin gin the Pod Farm disc and installing it. Authorizing it to my computer and what not, but now The level meter on my UX2 is not moving at all when I talk into the microphone. Im not sure exactly if there is  certain box I need to hit, but im guessing it is a really simple thing. I have not messed around wiht the Pod Farm drivers at all.
  • Upvote 3
  • 1 month later...
I have the same setup. UX2 and AT2035.  Fully updated UX2 and Farm 2 running. Phantom power on but I cant even get the led on my mic to glow. Tried everything BigChas wrote. Any other ideas?
Update!
Sigh. I'm an idiot.  Even tho I am not sure of this is true but I came to realize that maybe at2035 doesnt have a blue led like at2020 usb mic does.
  • 1 month later...
my garageband was open while i was trying to get my pod farm UX2 to acknowledge i have a mic plugged into line 1, and when i accidentally hit the record button, my UX2 was reading the sounds of the metronome from garageband.. but the dials won't budge when tapping or talking into the mic. help would be much appreciated
  • 1 month later...
Hi zacharybuckler and nbron21
   Zacharybuckler, that is unfortunate. Is there sound coming out the mic? What setup are you using? Windows/Mac? - and are you using a programme to run things from or just pod farm?
Nbron21, I think that might be that you need to go into the thing called Line 6 Audio-Midi Devices (you can find this by going into podfarm standalone and then - File - Preferences - Hardware and click on Tonedirect settings. The box that comes up has a section which allows you to choose input for the dial. It is possibly set to something else. Click the tab called inputs and recording and then select input. Hopefully this will be the reason.
God Bless,
David
  • 1 year later...
  • 10 months later...
hi there, i am having the same problem. updated driver, monkey, farm etc. on my ux2 (bought in 2008); then briefly got it to work with a microphone after hours of fumbling. lo and behold, i tried plugging in a guitar and it stopped working; i.e. i alternatively have no movement in the input level on the interface or the farm thingy says the sounds are not loaded. no sound in both cases, obvs. after trying to turn things off and on again for hours, i'm a bit peeved now to say the least. i have a macbook pro on yosemite, btw. grateful for any hints whatsoever! cheers from the north of germany.
Turn down the volume,
engage the phantom power,
then turn the mic volume back up.
Condenser mics require phantom power, the UX2 has phantom power,... use only for condenser mics.
That's on page 2.4 in the manual (17 of 82, online manual).
  • 5 months later...
Hi!
I am using a TonePort UX2 on a Mac running El Capitan (i have the latest drivers) I am using Logic Pro X.
I am trying to record vocals using a dynamic AKG P5S microphone and getting no signal come through at all.
I have tried both xlr inputs on the front and turned up the levels, but no joy.
Please help!
Hello!
I recently reset my PC (Windows 10 option), and ever since then, Pod Farm 2 isn't picking up my microphone at all, and no input is coming through my Line 6 UX2 mixer. I have followed everything on this thread, and nothing has worked. All drivers are updated to the latest, and pod farm 2 is running in compatibility mode for Windows 8, since troubleshooting recommended it. I'm also using an AT 2035 condenser mic, plugged into Mic1, with the phantom power turned on. I'm at a complete loss here.
  • 3 years later...
Please don't yell at me for necroing an old thread, but I just ran into this issue and because this was the first thing that popped up, I wanted to make sure this question was actually answered.
If your mic is not picking up, more than likely, you do not have your mic selected in the Pod Farm 2 software. Click the "Mixer View" button in Pod Farm and under the first Input drop down menu, make sure "Mic 1" is selected.
  • 4 years later...
OMG, I almost bought a new interface for the mic XLRs seemed completely dead. Thank you very much. In a way silly that and app that comes with it determines the deadness of the mic IN.
