LAEDGE Posted January 9, 2014 Share Posted January 9, 2014 Hi guysBeen jamming today with my LTD SC-607B through the POD HD Bean, and all was good at first. Switched it off, came back later and then, without tweaking my patch at all, I started to get this annoying noise trailing my chugs. I have tried out a few lead cords and the same thing, and I am getting the same noise through both bridge and neck pick ups.Here is a recording of what I mean. Its driving me crazy. Like I said, it was fine just minutes earlier until I turned it off for a while. Came back and here we are.https://soundcloud.com/sdsm/my-song-2Anybody else experienced this or something similar? I just put in a brand new battery for my EMG's too I have tried plugging the POD into other power sockets around the house and same thing I have tried another guitar with passive pick ups and same thing This comes on randomly from time to time Quote Link to comment Share on other sites More sharing options...
scottyo78 Posted January 9, 2014 Share Posted January 9, 2014 Hmmm... that actually sounds fairly normal to me... in that its a typical high gain, semi noisy sound. If you're sure it was stone silent after a dead-stop chug then here' a couple things to check: 1. Did a reverd or delay get turned on inside the POD? 2. Does your amp* or DAW* have a reverb or such enabled? 3. Did you reposition your amp or power strip (slight "ground" noise) for the POD or amp. 4. Did you reposition your guitar when playing it (face the wall now vs. the window before). Many times facing toward speakers, mics or an amp at certain angles causes noise. *not sure if you're using an amp or DAW. 1 Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted January 10, 2014 Share Posted January 10, 2014 LAEDGE, Does the noise occur from preset to preset? I would try plugging it in something with proper grounding i.e. a decent power strip or even better a Power Conditioner. Also, are you currently using a Noise Gate? If not I would consider placing one at either the end of your pre-effects or the beginning of your post-effects? I am not sure how new you are to this kind of setup but a noise gate is an essential part of most metal guitarists rig and sounds like the issue you are having is the same one most metal guitarist run into. It will definitely clean up the noise between playing, especially if you are using active pickups with a lot of gain. im thinking it is the later of the two. 1 Quote Link to comment Share on other sites More sharing options...
LAEDGE Posted January 10, 2014 Author Share Posted January 10, 2014 Hmmm... that actually sounds fairly normal to me... in that its a typical high gain, semi noisy sound. If you're sure it was stone silent after a dead-stop chug then here' a couple things to check: 1. Did a reverd or delay get turned on inside the POD? 2. Does your amp* or DAW* have a reverb or such enabled? 3. Did you reposition your amp or power strip (slight "ground" noise) for the POD or amp. 4. Did you reposition your guitar when playing it (face the wall now vs. the window before). Many times facing toward speakers, mics or an amp at certain angles causes noise. *not sure if you're using an amp or DAW. Hi Im just going straight into the computer via usb and into Logic. There are no changes to my patch or the POD at all and didnt reposition anything. So far the only thing that I can think of is perhaps power inteference. I am using a fairly straight forward patch, just noise gate, TS, Tube Compressor and the Treadplate sim, just a nice basic patch without any delay or reverb. As I said this often comes on quite randonly, I am wondering if any other POD HD Hi Gain users get this? Im hoping it isnt my unit :( Quote Link to comment Share on other sites More sharing options...
LAEDGE Posted January 10, 2014 Author Share Posted January 10, 2014 Hmmm... that actually sounds fairly normal to me... in that its a typical high gain, semi noisy sound. If you're sure it was stone silent after a dead-stop chug then here' a couple things to check: 1. Did a reverd or delay get turned on inside the POD? 2. Does your amp* or DAW* have a reverb or such enabled? 3. Did you reposition your amp or power strip (slight "ground" noise) for the POD or amp. 4. Did you reposition your guitar when playing it (face the wall now vs. the window before). Many times facing toward speakers, mics or an amp at certain angles causes noise. *not sure if you're using an amp or DAW. Oh and it wasnt stone silent before, just didnt have that 'whoosh' noise. Quote Link to comment Share on other sites More sharing options...
timthompson Posted March 16, 2014 Share Posted March 16, 2014 Hold down you VEIW button til a new menu pops up, use down button til you get to input. set source 2 input to variax and it will kill the noise. hope this helps. TimThompson (Tweekhead) Quote Link to comment Share on other sites More sharing options...
