rangan Posted September 11, 2019 Share Posted September 11, 2019 Hello I'm having trouble connecting my pod hd 500 to my new laptop. My pod HD 500 works fine on my old laptop. Both of my laptops are running windows 10 64bit. Only difference is my new laptop all usb ports are USB 3.0 . My old laptop does not have a usb 3.0 so don't know if pod hd works on usb3. I tried installing driver directly using driver software also tried using line 6 monkey. also tried uninstalling and reinstalling again. any suggestion would be really helpful. Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted September 20, 2019 Share Posted September 20, 2019 Only thing I can think of would be to insure that you have the bios updated and chipset drivers updated...One thing you could look for in the bios is setting for USB...In some BIOS it is possible to change the version of the USB on the bios...if you have more than one root controller, there could be 2 settings. My old Sony is like that as it was a first generation USB3...so I only have one USB3 port...and my HD will crash after about an hour on that port...rock solid on the USB2 port...also Windows 10 64....Although I have had that exact issue since it had Windows 8...long time...However, I do not have connectivity issues...Only that USB3 port with HD will cause BSOD in about an hour. Quote Link to comment Share on other sites More sharing options...
jlong4701 Posted March 21, 2020 Share Posted March 21, 2020 Similar issue here. mine are all USB3. is this win 10 new laptop going to work for my POD HD500X? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 21, 2020 Share Posted March 21, 2020 54 minutes ago, jlong4701 said: Similar issue here. mine are all USB3. is this win 10 new laptop going to work for my POD HD500X? IIRC there is a sort of USB3 to USB2 driver downgrade procedure to make the USB3 ports working only as USB2, but I don't remember where I saw it. Who knows, it might work, if it could be a viable solution for you, try a search for it online. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
joel_brown Posted March 22, 2020 Share Posted March 22, 2020 https://www.dell.com/community/Laptops-General-Read-Only/Is-it-possible-to-downgrade-USB3-to-USB2-using-a-generic-driver/td-p/3864128 Basically it says to remove the Intel USB 3.0 drivers and run the Microsoft Generic USB2 drivers. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 22, 2020 Share Posted March 22, 2020 This has been my concern from day one.... My last rig lasted 30 years (and it still worked when I replaced it). I can only hope that this one remains completely functional just as long. But that means we need the accessories (drivers, edit, etc) to also be maintained. Otherwise, the product is the equivalent of toilet paper. Use it and throw it away. Does Line 6 really want to be thought of as something we wipe your lollipop with... 1 Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 22, 2020 Share Posted March 22, 2020 3 hours ago, pianoguyy said: Otherwise, the product is the equivalent of toilet paper. Use it and throw it away. Does Line 6 really want to be thought of as something we wipe your lollipop with... LOL!! Quote Link to comment Share on other sites More sharing options...
joel_brown Posted March 23, 2020 Share Posted March 23, 2020 It's not just Line6. A friend started having issues with his Tascam 1604 audio interface. It started randomly locking up about 6 months ago. I told him to see if it was plugged into a USB 3.0 port, which it was. He switched it to a USB 2.0 port and so far it's working great again. My understanding is there were some tricks you could with USB 2.0 and audio streaming that weren't exactly supported. USB 3.0 is backwards compatible with supported programming methods only. Quote Link to comment Share on other sites More sharing options...
bsmith55 Posted April 6, 2020 Share Posted April 6, 2020 I had a problem trying to load HD500 drivers through Monkey. Tech Support told me to bypass Monkey altogether, and get them directly from the website. Quote Link to comment Share on other sites More sharing options...
MotherGo0se Posted April 7, 2020 Share Posted April 7, 2020 20 hours ago, bsmith55 said: I had a problem trying to load HD500 drivers through Monkey. Tech Support told me to bypass Monkey altogether, and get them directly from the website. Quote Link to comment Share on other sites More sharing options...
Gimme38 Posted April 30, 2020 Share Posted April 30, 2020 Hi folks! I have the same problem now with HD500 on Win 10 - after the drivers' installation is finished, i plug in the USB cable and then the System kicks me away to the blue screen. Does anybody solved that problem? 1 Quote Link to comment Share on other sites More sharing options...
ykaraman Posted October 1, 2021 Share Posted October 1, 2021 Does Line 6 test their software with the Most Popular Operating System Windows 10????? Quote Link to comment Share on other sites More sharing options...
Gomez_dnb Posted December 18, 2021 Share Posted December 18, 2021 Same Problem here. New Notebook has USB 3.0 and 3.1 only. Same in the Dockingstation. Is this Problem solved? I can install the driver, and when it says to Plug in the Cable of the POD HD500X nothing happens, the device Manager of Windows 10 says Problem with the driver. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted December 19, 2021 Share Posted December 19, 2021 14 hours ago, Gomez_dnb said: Same Problem here. New Notebook has USB 3.0 and 3.1 only. Same in the Dockingstation. Is this Problem solved? I can install the driver, and when it says to Plug in the Cable of the POD HD500X nothing happens, the device Manager of Windows 10 says Problem with the driver. If you want to force a 3.0 port to 2.0 mode you need to use a USB 2.0 cable so the new pin is completely lifted...This isn't a not a driver issue as HD is fixed at 2.0 in the hardware. Your interface should detect that and go to 2.0 mode on a 3.0 cable, but that does not always work. You might want to also check for motherboard firmware updates, bios, chipset etc...all plays into the hardware being up to spec since the machine is new...new motherboards always get tweaked post release... Also check you your bios UEFI to see if it had a mode switch for your USB...Could be called legacy mode... Quote Link to comment Share on other sites More sharing options...
Gomez_dnb Posted December 20, 2021 Share Posted December 20, 2021 On 12/19/2021 at 4:13 AM, spaceatl said: If you want to force a 3.0 port to 2.0 mode you need to use a USB 2.0 cable so the new pin is completely lifted...This isn't a not a driver issue as HD is fixed at 2.0 in the hardware. Your interface should detect that and go to 2.0 mode on a 3.0 cable, but that does not always work. You might want to also check for motherboard firmware updates, bios, chipset etc...all plays into the hardware being up to spec since the machine is new...new motherboards always get tweaked post release... Also check you your bios UEFI to see if it had a mode switch for your USB...Could be called legacy mode... I`ve tried all that things. Now i know much more about my lenovo laptop. It has only USB 3.2 Ports, 2 x A-shaped and 2 x C-shaped (Thunderbolt) same in the dockingstation, i know the Port is the Problem, anyone more Ideas? There are no options in the Bios to switch something. Anyone more ideas? Perhaps an Adapter from USB- A to C? So the Thunderbolt is more compatible than the USB 3.2 A-shaped Ports? Think about buying an Quad Cortex.... Quote Link to comment Share on other sites More sharing options...
spaceatl Posted December 20, 2021 Share Posted December 20, 2021 did you try a 2.0 hub? Quote Link to comment Share on other sites More sharing options...
Gomez_dnb Posted December 20, 2021 Share Posted December 20, 2021 22 minutes ago, spaceatl said: did you try a 2.0 hub? Not till now, do you See a Real Chance? Its not easy to get a 2.0 hub this days Quote Link to comment Share on other sites More sharing options...
ThesmithsMu Posted February 23, 2022 Share Posted February 23, 2022 Hello Guys I'm having a problem in POD HD EDIT, when trying to drag a work path into the pedalboard, it's not working. Before I installed it fine, I already uninstalled and reinstalled the drivers and nothing Quote Link to comment Share on other sites More sharing options...
