Amarasco Posted December 18, 2019 Share Posted December 18, 2019 I'm experiencing terrible noises due to lack of clock sync between Reaper and Helix, used as an USB audio interface. I tried to set the same sample rate but the noises are still there in the recording. Can someone please help me fix this issue and explain me (like I'm a 5 y o kid) how to make the Helix the master and Reaper the slave? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 18, 2019 Share Posted December 18, 2019 What kind of noises are you talking about, exactly? Quote Link to comment Share on other sites More sharing options...
Amarasco Posted December 18, 2019 Author Share Posted December 18, 2019 6 hours ago, phil_m said: What kind of noises are you talking about, exactly? Like pops, digital squeaky noises, that happens during the playback. I tried everything I could to the best of my knowledge but I didn't fix this problem. Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 18, 2019 Share Posted December 18, 2019 7 minutes ago, Amarasco said: Like pops, digital squeaky noises, that happens during the playback. I tried everything I could to the best of my knowledge but I didn't fix this problem. That would typically be more related to your buffer settings rather than sample rate settings. Quote Link to comment Share on other sites More sharing options...
Amarasco Posted December 18, 2019 Author Share Posted December 18, 2019 5 minutes ago, phil_m said: That would typically be more related to your buffer settings rather than sample rate settings. Here's an example. What should I do to avoid it? Noises.mp3 Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 18, 2019 Share Posted December 18, 2019 13 minutes ago, Amarasco said: Here's an example. What should I do to avoid it? Noises.mp3 Those are classic buffer underrun sounds. You can increase the buffer size in the Audio Device menu in Reaper. I think the default may be 256 or 512. You can try setting it higher. If you're not direct monitoring, it doesn't matter all that much. The other thing to do is check your system for conflicts that could be causing issues. Often times things like network adapters or Bluetooth adapters can cause issues. This program will tell what's causing problems: https://www.resplendence.com/latencymon Quote Link to comment Share on other sites More sharing options...
Amarasco Posted December 18, 2019 Author Share Posted December 18, 2019 20 minutes ago, phil_m said: Those are classic buffer underrun sounds. You can increase the buffer size in the Audio Device menu in Reaper. I think the default may be 256 or 512. You can try setting it higher. If you're not direct monitoring, it doesn't matter all that much. The other thing to do is check your system for conflicts that could be causing issues. Often times things like network adapters or Bluetooth adapters can cause issues. This program will tell what's causing problems: https://www.resplendence.com/latencymon Thanks so much Phil, I'll follow your suggestions! Quote Link to comment Share on other sites More sharing options...
