POD HD500x - corrupted driver on MacOS Lion 10.7.5
Smashcraaft
I have problems on an older Mac Pro with the MacOS OS-X Lion 10.7.5
The latest driver is shown as 7.3.7 but no matter how I install it (via the monkey or manually) the driver neither does update in the monkey ("update selection") nor let me connect the POD via HD Edit or the licence manager. HD Edit crashes on directly start.
The licence manager shows the computer as activated but no device.
The driver is shown as outdated even if the POD is not connected.
Of cause I tried to uninstall the driver via the uninstall-tool and to restart the mac.
Of cause I have tried 2 different USB cables (both working on another machine).
I have tried everything & several times… no luck!
Based on what I can see at the moment in the DOWNLOADS section of this site the latest POD HD500X driver for Mac OS X seems to be v.7.6.8 (not 7.3.7).
---> https://line6.com/software/readeula.html?rid=8376
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Not when it comes to the outdated MacOS Lion (10.7) which has to be fed with the 7.3.7 as the download-section and the Monkey states.
2 hours ago, Smashcraaft said:
Checked it once again and it's true. Latest is...
Version 7.3.7
Released 11/6/14
This is what I see:
(notice the compatible OS list)
8AWID4S.png?1
then if you press the GET DOWNLOAD button you get this: https://line6.com/software/readeula.html?rid=8376
1 hour ago, Smashcraaft said:
Attention!
Mountain Lion is not the same as Lion. The last one is older and not compatible with the later versions.
If you search the list for Lion you will land on the 7.3.7 too.
You are right!
This makes it obvious that I've never been a Mac user.
Hope you find soon a solution somehow. Good luck.
  • 2 months later...
  • 3 months later...
