gnostiquette Posted January 23, 2020 Share Posted January 23, 2020 I'm having a very specific problem with the G-string piezoelectric pickup on my Variax 500. Much of the time, the signal goes dead; there is no sound coming from it. However, after pressing down on it, for a few seconds to a few minutes the sound will return, but it will then get fuzzy and fade out to nothing again. This started a week or two ago. Is this a grounding issue, a signal wire issue, or something entirely different? And how can it be fixed? Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 23, 2020 Share Posted January 23, 2020 It's likely a dirty contact point in the saddle where the piezo sits or a failing piezo. Try moving the string aside and applying some electronic contact cleaner to the piezo surface, If that doesn't resolve things you may need to replace the piezo - sometimes they fail. If replacing one I would replace the whole set; the rest may not be far behind in terms of failure. Contact Line 6 for availability. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 23, 2020 Share Posted January 23, 2020 For original Variax piezos,... https://www.fullcompass.com/prod/114557-line-6-11-11-0001-piezo-pickup-for-variax-300-500-700 Quote Link to comment Share on other sites More sharing options...
janjanjan Posted January 24, 2020 Share Posted January 24, 2020 Or put in Ghost saddles. A bit tricky to solder but this will give proper ground and improved improved sound quality for each string. https://graphtech.com/collections/ghost-pickup-systems-guitar-saddle Quote Link to comment Share on other sites More sharing options...
amiroliez Posted July 6, 2022 Share Posted July 6, 2022 I replace dead piezo with diy piezo built from acoustic piezo then i cut, it working perfectly Quote Link to comment Share on other sites More sharing options...
