garbanzo Posted March 17, 2020 Share Posted March 17, 2020 I have just downloaded the updater and see that it is a dmg file. On my W10 machine I am asked with what program do I want to open the file. What is my answer to that? I realise that I have been posed before this question before and cant quite remember hw I solved it. What do you more experienced users, and especially those with better memory's than mine do? Thanks in advance garbanzo Quote Link to comment Share on other sites More sharing options...
monsieurkozo Posted March 17, 2020 Share Posted March 17, 2020 You took the wrong file garbanzo. DMG are for MAC. Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 17, 2020 Share Posted March 17, 2020 1 hour ago, garbanzo said: I have just downloaded the updater and see that it is a dmg file. On my W10 machine I am asked with what program do I want to open the file. What is my answer to that? I realise that I have been posed before this question before and cant quite remember hw I solved it. What do you more experienced users, and especially those with better memory's than mine do? Thanks in advance garbanzo Hi, It appears that you have inadvertently managed to download the Mac Version of the firmware. When you are on the Line 6 Download page, from the “All Software” tab select “HX Edit”, then under the third grey coloured tab labelled “All OS” select “Windows 10” from the drop down menu. This will take you to the correct page to download the Updater required. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
garbanzo Posted March 17, 2020 Author Share Posted March 17, 2020 3 hours ago, datacommando said: Hi, It appears that you have inadvertently managed to download the Mac Version of the firmware. When you are on the Line 6 Download page, from the “All Software” tab select “HX Edit”, then under the third grey coloured tab labelled “All OS” select “Windows 10” from the drop down menu. This will take you to the correct page to download the Updater required. Hope this helps/makes sense. Perfect dc, thanks! 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 17, 2020 Share Posted March 17, 2020 If you're updating a Helix (vs a G10) download and install the HX Edit file, NOT the Updater. That file will install the Updater and all drivers. If you try to update without installing HX Edit, you might have problems. 1 Quote Link to comment Share on other sites More sharing options...
garbanzo Posted March 17, 2020 Author Share Posted March 17, 2020 4 hours ago, rd2rk said: If you're updating a Helix (vs a G10) download and install the HX Edit file, NOT the Updater. That file will install the Updater and all drivers. If you try to update without installing HX Edit, you might have problems. Thanks rd2rk! I am not sure how i> managed to make this mistake, but it is now rectified. I hope that if some else makes the same this thread will be of help. Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted March 18, 2020 Share Posted March 18, 2020 8 hours ago, rd2rk said: If you're updating a Helix (vs a G10) download and install the HX Edit file, NOT the Updater. That file will install the Updater and all drivers. If you try to update without installing HX Edit, you might have problems. THIS! THANK-YOU! I was trying the updater for my new Helix last night with no success, and just did the HX Edit path and it is all now working! Updating Helix firmware now! Quote Link to comment Share on other sites More sharing options...
garbanzo Posted March 18, 2020 Author Share Posted March 18, 2020 8 hours ago, Lone_Poor_Boy said: THIS! THANK-YOU! I was trying the updater for my new Helix last night with no success, and just did the HX Edit path and it is all now working! Updating Helix firmware now! Cool, this means you have both a tremendous and bewildering exprience if front of you. 1 Quote Link to comment Share on other sites More sharing options...
