Replacement washers for Helix Exp pedal?
DannyMcO
Finally opened up my Helix to lubricate the pedal...
...and found that one of the shoulder washers (the cylindrical ones that go around the bolt, with a perpendicular flat section) had actually broken.
Where the heck does one get replacements for it? I don't even know what precise size it is as it seems to be metric, so I can't just order it online.
And FullCompass does not have them.
Help!
If no one else replies with the correct part number, you may have to call support and see if they will give you the part number or give/sell you a bushing kit.  Line 6 support posted this vid 3 years ago on lubrication and replacement of the bushings but didn't list the part number.
There are three of those type of flanged washers:
30-03-0069: has the largest flange
30-03-0075: same length as first listed part, but the flange is smaller
30-03-0074: same size flange as first listed part, but part length is shorter
These came in the kit mentioned by lungho. Each part is individually bagged with a part number sticker.
  • 1 year later...
