GeorgeMavrogenis Posted June 25, 2020 Share Posted June 25, 2020 Hello! I would like to replace my pedalboard with either a Pod Go or a Helix LT, but first I would like to make sure that I can achieve the same setup that I use now with the Pod Go's/ Helix LT's inbuilt expression pedal. On my pedalboard I am using a wah pedal which is always on and mostly parked on treble and also a delay pedal with a connected expression pedal that controls the repeats=feedback. My specific questions regarding the Pod Go and/or the Helix LT are: 1) Can I assign the inbuilt expression pedal to control the repeats of a tape delay? 2) If yes, can I simultaneously have a wah pedal that is permanently on full treble without controlling it through the expression pedal? 3) If yes, could I also control the wah with the same (NOT an additional one) expression pedal by switching presets mid-song and thus effectively use the inbuilt expression pedal for both delay and wah? Quote Link to comment Share on other sites More sharing options...
Melissiah Posted June 25, 2020 Share Posted June 25, 2020 You can do everything with knowledge and programming. I use the expression pedal for 3 things on the same preset. It always send midi CC 11 to control my external whammy who is hidden in my roadcase. I use it to control wah and volume that can alternate with toe switch. You can assign almost any parameter almost anywhere. Quote Link to comment Share on other sites More sharing options...
Melissiah Posted June 25, 2020 Share Posted June 25, 2020 Oh I forgot something. I waste a footswtich on the board to control the on/OFF status of the volume block to be able to control my whammy without volume or wah engaged. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 25, 2020 Share Posted June 25, 2020 1 hour ago, GeorgeMavrogenis said: Hello! I would like to replace my pedalboard with either a Pod Go or a Helix LT, but first I would like to make sure that I can achieve the same setup that I use now with the Pod Go's/ Helix LT's inbuilt expression pedal. On my pedalboard I am using a wah pedal which is always on and mostly parked on treble and also a delay pedal with a connected expression pedal that controls the repeats=feedback. My specific questions regarding the Pod Go and/or the Helix LT are: 1) Can I assign the inbuilt expression pedal to control the repeats of a tape delay? 2) If yes, can I simultaneously have a wah pedal that is permanently on full treble without controlling it through the expression pedal? 3) If yes, could I also control the wah with the same (NOT an additional one) expression pedal by switching presets mid-song and thus effectively use the inbuilt expression pedal for both delay and wah? 1) Yes 2) Yes. You can completely disengage the Wah Block from the Expression Pedal and use the pedal for other things.. 3) The Expression Pedal can control whatever you want in different presets, it's not Global. Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted June 25, 2020 Share Posted June 25, 2020 Though depending on your pedalboard size now (and budget!), it would be wiser to get the LT because the pod go restricts you a little. Pod go 1. volume locked 2. wah locked 3. maybe a distortion 4. maybe a chorus 5. Amp locked 6. maybe reverb 7. maybe delay 8. eq locked It's a little tight... not a lot of flexibility and the both can do what you want with the expression pedal Quote Link to comment Share on other sites More sharing options...
GeorgeMavrogenis Posted June 25, 2020 Author Share Posted June 25, 2020 Thanks everybody for the replies! I am covered 1 Quote Link to comment Share on other sites More sharing options...
