alheeren Posted September 6, 2020 Share Posted September 6, 2020 Hey, gang! I’m new to the Variax and I need some input. (JTV89F) I have my Helix patches setup to automatically select the Variax instrument I want using snapshots. It seems to work well. Typical Clean, Crunch, Gain, Solo, 12 String acoustic, 6 String acoustic and banjo. I have my input for my patch on “multi”. It seems to me that everything sounds pretty good but call me crazy, sometimes I hear what is possibly the mag pickups under the Variax tone/model. It’s almost like I’m hearing the dynamics of a “dry signal” under the Variax model even when using a heavily distorted snapshot. This may also explain why if I drop tune an acoustic model a half step it sounds terrible. I’m only using a Variax VDI cable. Any input would be appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted September 7, 2020 Share Posted September 7, 2020 Double check that the mags level is turned off either within the Helix patch and check the configuration in the Variax itself with the Workbench HD editor. This is also assuming your playback level is high because if you're listen at lower volumes you might be hearing the strings them self if that makes sense to you. Jd Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted September 7, 2020 Share Posted September 7, 2020 Check if you have any preset with "magnetic blend" on Workbench HD If yes, put it on O Quote Link to comment Share on other sites More sharing options...
alheeren Posted September 7, 2020 Author Share Posted September 7, 2020 Thanks, guys. I’ll try this today. I was also told to switch from “multi” to “Variax” for my inputs if using Variax model exclusively. If needed I’ll re-flash the firmware. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted September 7, 2020 Share Posted September 7, 2020 On 9/6/2020 at 2:21 PM, alheeren said: Hey, gang! I’m new to the Variax and I need some input. (JTV89F) I have my Helix patches setup to automatically select the Variax instrument I want using snapshots. It seems to work well. Typical Clean, Crunch, Gain, Solo, 12 String acoustic, 6 String acoustic and banjo. I have my input for my patch on “multi”. It seems to me that everything sounds pretty good but call me crazy, sometimes I hear what is possibly the mag pickups under the Variax tone/model. It’s almost like I’m hearing the dynamics of a “dry signal” under the Variax model even when using a heavily distorted snapshot. This may also explain why if I drop tune an acoustic model a half step it sounds terrible. I’m only using a Variax VDI cable. Any input would be appreciated. Thank you. You're hearing the guitar acoustically. Yes, I'm serious. If you're not turned up loud enough when using alt tunings it will sound awful because what's coming from your speakers are not the same pitches that reach your ears directly from the guitar itself. Dissonance is inevitable. Crank up enough, and you won't hear it anymore. Quote Link to comment Share on other sites More sharing options...
