loretnicolas Posted September 30, 2020 Share Posted September 30, 2020 Hi everyone, I'm searching an Helix Native Licence. If someone have one, I'm interested. loret.nicolas@gmail.com Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 30, 2020 Share Posted September 30, 2020 15 minutes ago, loretnicolas said: Hi everyone, I'm searching an Helix Native Licence. If someone have one, I'm interested. loret.nicolas@gmail.com Thanks Hi, A quick “heads up”. You will have to get in line, along with all those other people who have peppered this forum with the same request. Could take a while. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
loretnicolas Posted September 30, 2020 Author Share Posted September 30, 2020 Ok I didn't see that. I have a second hand Helix Floor and the need to have the pedalboard connected every time I want to tweak tone is just ... But I understand thank you for this point. Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 30, 2020 Share Posted September 30, 2020 10 hours ago, loretnicolas said: Ok I didn't see that. I have a second hand Helix Floor and the need to have the pedalboard connected every time I want to tweak tone is just ... But I understand thank you for this point. No problem, I simply wanted to make you aware of how many others are asking for the same thing. I am a little confused by your comment, “the need to have the pedalboard connected every time I want to tweak tone”. Tone tweaking is more usually done on the hardware unit, or by using HX Edit over USB - (along with Edit being a librarian app for your presets), even though HXN does do “drag and drop” on presets. Plus you will still need to hook up to your floor unit to get your “tone tweaks” back out into the hardware if you intend to use them in a live situation. HX Native tone manipulation is generally applied to a dry guitar (or whatever other) signal, in a similar way to re-amping, it’s not going to be much use on a recorded signal already full of fx. I think that might be a bit more than a small tone tweak. Although, I have probably misunderstood your intention. I have generally have several instances of HX Native running in Logic ProX across various tracks, but my Helix floor is almost always connected via USB to capture the original dry signal, along with the processed audio in as a guide, and my Tannoys are plugged in the Helix XLR output for monitor duties. I’m very used to the way that works for me as a studio rat. Everyone has a different way of working, so I guess it all depends on your workflow, and what interface you’re using for the guitar/bass, etc. Good luck in your search for copy of Native. Quote Link to comment Share on other sites More sharing options...
jasmedia Posted October 1, 2020 Share Posted October 1, 2020 Forgive my ignorance but can you not just go online and buy a licence? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 1, 2020 Share Posted October 1, 2020 8 minutes ago, jasmedia said: Forgive my ignorance but can you not just go online and buy a licence? Yes they can. But I imagine they're looking for a price discount, even though it's software. Perhaps it's a bit scratched and scuffed from all that transporting here and there? 1 Quote Link to comment Share on other sites More sharing options...
loretnicolas Posted October 8, 2020 Author Share Posted October 8, 2020 On 10/1/2020 at 1:01 AM, datacommando said: No problem, I simply wanted to make you aware of how many others are asking for the same thing. I am a little confused by your comment, “the need to have the pedalboard connected every time I want to tweak tone”. Tone tweaking is more usually done on the hardware unit, or by using HX Edit over USB - (along with Edit being a librarian app for your presets), even though HXN does do “drag and drop” on presets. Plus you will still need to hook up to your floor unit to get your “tone tweaks” back out into the hardware if you intend to use them in a live situation. HX Native tone manipulation is generally applied to a dry guitar (or whatever other) signal, in a similar way to re-amping, it’s not going to be much use on a recorded signal already full of fx. I think that might be a bit more than a small tone tweak. Although, I have probably misunderstood your intention. I have generally have several instances of HX Native running in Logic ProX across various tracks, but my Helix floor is almost always connected via USB to capture the original dry signal, along with the processed audio in as a guide, and my Tannoys are plugged in the Helix XLR output for monitor duties. I’m very used to the way that works for me as a studio rat. Everyone has a different way of working, so I guess it all depends on your workflow, and what interface you’re using for the guitar/bass, etc. Good luck in your search for copy of Native. In fact I would like to record a dry signal for exemple, then use an Helix Preset I made on Helix Native and tweak the tone to reach what I want to hear. I would like to be able to do that anywhere with just my laptop. (sorry for my english... french guy inside) On 10/1/2020 at 2:46 AM, jasmedia said: Forgive my ignorance but can you not just go online and buy a licence? My Helix Floor is a second hand and unfortunatly the serial number was already used. Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 8, 2020 Share Posted October 8, 2020 10 minutes ago, loretnicolas said: In fact I would like to record a dry signal for exemple, then use an Helix Preset I made on Helix Native and tweak the tone to reach what I want to hear. I would like to be able to do that anywhere with just my laptop. (sorry for my english... french guy inside) That is the way to do it when you are on the move - Bonne chance dans vos recherches. Quote Link to comment Share on other sites More sharing options...
loretnicolas Posted October 8, 2020 Author Share Posted October 8, 2020 Thanks a lot ;) 1 Quote Link to comment Share on other sites More sharing options...
vanilla Posted October 11, 2020 Share Posted October 11, 2020 You're not welcome. Teh latrea nomber ees 453. Foor fi tree. Plant one on me. Maybe plant a tree or kisses back with motley crue. Bye kay syanaruh. Lunch er dinner christina farlee tommy lee okay di box Quote Link to comment Share on other sites More sharing options...
loretnicolas Posted October 12, 2020 Author Share Posted October 12, 2020 When I will be able to understand what you wanna say to me, maybe I could answer something... Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, loretnicolas said: When I will be able to understand what you wanna say to me, maybe I could answer something... Ignore the fool. If you check his other posts, he is just filling the forum with crazy stuff. Possibly needs psychiatric help. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
loretnicolas Posted December 2, 2020 Author Share Posted December 2, 2020 Well I've got a licence now. I bought it from Line 6 for 99 dollars. They have finally accepted my proposal as a second hand Helix Floor owner. So thank you very much to Line 6. I now have a JTV 69', an Helix Floor and Helix Native ! Cool ! 1 Quote Link to comment Share on other sites More sharing options...
