k2mia Posted October 3, 2020 Share Posted October 3, 2020 Hi All, New to the Variax world as of last week, been only using a Helix for 6 weeks so really new to all of this. I tried searching for threads about my specific problem but am coming up short... I am trying to create a preset which has a blend of a Variax acoustic model mixed in with the magnetics (which I want to have just slight breakup). I watched a video (I think was a Line6 video) about setting this up with two independent signal paths and I am able to reproduce some of this, but the acoustic volume is so low that unless I turn the magnetics volume down to almost 0 I can't hear the acoustic at all. Do you guys know of any more in-depth tutorials that go through this process (for using both the Variax model and mags signal paths together)? Is there something simple I am missing? Thank you for any suggestions! :) -Andy Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 3, 2020 Share Posted October 3, 2020 I don't have the Helix But Do you mean that you want a acoustic sound only and can have a acoustic blend, I mean switch between the two? Make a chain with the acoustic and as VARIAX INPUT Make a chain with the acoustic and as MAGs INPUT Now I repeat I don't have the Helix, but this is another way Put a volume pedal at the end of chain 1 with settings 0% - 100% Put a volume pedal at the end of chain 2 with settings 100% -0% And no normaly you can add the blend with your pedal Depend what you want you can limit the blend at 50% or 20% etc.. Quote Link to comment Share on other sites More sharing options...
k2mia Posted October 4, 2020 Author Share Posted October 4, 2020 Thank you, I set up something like this and I can probably make it work. I don't have any amp/cab on the acoustic model path so what would be the best way to boost the volume cleanly? Thanks! -Andy Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 4, 2020 Share Posted October 4, 2020 To boost the volume of your acoustic you can try : 1- Workbench and boost the volume of your preset (bottom ) also if the sound is too boomy you can adjust the volume of each string 2 - Use comp 3 - Use the boost/EQ mod if this exist on the Helix try one or a combination 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 4, 2020 Share Posted October 4, 2020 4 - Increase the Level of the Output block on the acoustic guitar path. 1 Quote Link to comment Share on other sites More sharing options...
k2mia Posted October 4, 2020 Author Share Posted October 4, 2020 This helps alot, thank you guys! :) -Andy Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 13, 2020 Share Posted November 13, 2020 There is a mic preamp (only 1 I think) that you could use to boost the level. I use the LA comp for a lot of volume adjusting as well. Just put it last in the chain. Quote Link to comment Share on other sites More sharing options...
