cfppro123 3 Posted November 11, 2020 I am trying to record using some of the awesome Helix panning effects in Garageband.I am using Helix as the recording interface but Garageband defaults to mono. Does anyone know to get Garageband to record stereo direct from Helix? Thank you, Quote Share this post Link to post Share on other sites
datacommando 752 Posted November 12, 2020 20 hours ago, cfppro123 said: I am trying to record using some of the awesome Helix panning effects in Garageband.I am using Helix as the recording interface but Garageband defaults to mono. Does anyone know to get Garageband to record stereo direct from Helix? Thank you, Hi, Here ya go! https://support.apple.com/kb/PH24928?locale=en_US Hope this helps/makes sense. 2 Quote Share this post Link to post Share on other sites
codamedia 909 Posted November 12, 2020 On 11/11/2020 at 9:34 AM, cfppro123 said: I am using Helix as the recording interface but Garageband defaults to mono. If tracks "default" to mono, that suggests there should be a way to change it to "stereo". OR, don't accept the default and add a stereo track. If for any reason you cannot change a single track to stereo or add a stereo track, then you can still do it the old fashion way which is (IMO) the best way. Setup two mono tracks to record.... Set one track to record the Helix LEFT side Set the other track to record the Helix RIGHT side Hard pan each track left/right... Result = stereo 1 Quote Share this post Link to post Share on other sites
cfppro123 3 Posted November 12, 2020 Thank you very much. The link in the first response showed me what I need. A simple answer I just couldn't find it. 1 1 Quote Share this post Link to post Share on other sites
