bartpuglise Posted November 13, 2020 Share Posted November 13, 2020 I’m using a expression pedal set up for an Auto-wah effect. Is there any way to activate a foot switch that would indicate on-off status only?? I would like to be able to visually confirm the wah effect is on or off Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 13, 2020 Share Posted November 13, 2020 43 minutes ago, bartpuglise said: I’m using a expression pedal set up for an Auto-wah effect. Is there any way to activate a foot switch that would indicate on-off status only?? I would like to be able to visually confirm the wah effect is on or off Don't think so, at least not without also assigning control of the block to that same footswitch. But the block itself already indicates what state it'sil in anyway...when it's lit up the effect is on, grayed out and it's off. That's as good as its gonna get. Quote Link to comment Share on other sites More sharing options...
CraigGT Posted November 13, 2020 Share Posted November 13, 2020 6 hours ago, cruisinon2 said: Don't think so, at least not without also assigning control of the block to that same footswitch. But the block itself already indicates what state it'sil in anyway...when it's lit up the effect is on, grayed out and it's off. That's as good as its gonna get. I tried that but the footswitch overrides the pedal switch. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 13, 2020 Share Posted November 13, 2020 13 minutes ago, CraigGT said: I tried that but the footswitch overrides the pedal switch. Which was precisely my point... you can't assign the same effect to multiple places simultaneously. If he wants a footswitch to light up when an effect is engaged, then he has to assign it to the footswitch in question... obviously creating a problem when one wishes to control said effect with the expression pedal. Quote Link to comment Share on other sites More sharing options...
bartpuglise Posted November 16, 2020 Author Share Posted November 16, 2020 Yep I tried that earlier I was just wondering if someone had a work around that I was unaware of. THANKS Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted November 17, 2020 Share Posted November 17, 2020 What am I missing here? I presume the EP is for mix, so why not have a stomp bypass or a snapshot bypass? Quote Link to comment Share on other sites More sharing options...
