Hatman777 Posted November 24, 2020 Share Posted November 24, 2020 Hello All So another Noob Question As i assign a Wah to first Block then I use My pedal to Control the Wah Nothing happens My setting is EXP1 which is somewhat greyed out and when i use the EXP pedal it shows % value instead of showing EXP1 greyed out Now i tried Assigning the wah to separate PEdal and still nothing is there a setting In global that needs to be activated ? i read about that if you press hard on the toe it switches something ive tried pressing really hard and nothing happens thanks all for any help or guidance Quote Link to comment Share on other sites More sharing options...
C4TH Posted November 24, 2020 Share Posted November 24, 2020 Try using the “Learn Function”. Then you should be good to go. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 25, 2020 Share Posted November 25, 2020 13 hours ago, Hatman777 said: thanks all for any help or guidance Helix 3.0 Owner’s Manual - Rev E - English Page 8 Expression Pedal Move the expression pedal to control volume, wah, or a combination of amp and/or effects parameters. Activate the hidden toe switch to toggle between EXP 1 and EXP 2. (The scribble strip above tells you which one is active.) If an external pedal is connected to the rear panel EXP 2 jack, the built-in pedal becomes EXP 1 only.—see “Controller Assign” (Page 53j etc. plus page 66 re EXP 1, 2 and 3 position Determines whether the Helix expression pedal positions are recalled per snapshot, per preset, or applied globally. If you want a Volume Pedal or Wah to maintain its position when switching presets, set this to “Global.” Could be worth browsing through. Or, reset your Globals from the backup file you made with HX Edit. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Hatman777 Posted November 25, 2020 Author Share Posted November 25, 2020 9 hours ago, datacommando said: Helix 3.0 Owner’s Manual - Rev E - English Page 8 Expression Pedal Move the expression pedal to control volume, wah, or a combination of amp and/or effects parameters. Activate the hidden toe switch to toggle between EXP 1 and EXP 2. (The scribble strip above tells you which one is active.) If an external pedal is connected to the rear panel EXP 2 jack, the built-in pedal becomes EXP 1 only.—see “Controller Assign” (Page 53j etc. plus page 66 re EXP 1, 2 and 3 position Determines whether the Helix expression pedal positions are recalled per snapshot, per preset, or applied globally. If you want a Volume Pedal or Wah to maintain its position when switching presets, set this to “Global.” Could be worth browsing through. Or, reset your Globals from the backup file you made with HX Edit. Hope this helps/makes sense. Yes Thanks Datacommando, will try that out for sure 1 Quote Link to comment Share on other sites More sharing options...
plunky Posted November 26, 2020 Share Posted November 26, 2020 My tip: it really requires quite a forceful press on the toe to invoke the wah...for days I was just being too gentle with it, and was frustrated like you that I just couldnt get it to work. Then in anger I really toed it hard and then it all worked. YMMV! 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 1, 2021 Share Posted March 1, 2021 I don't know if this has been mentioned but I believe the Wah is automatically assigned to EXP2 and the Volume pedal to EXP1. And the toe switch is automatically assigned to switch between 1 & 2. So if you saved your patch with EXP1 being selected, the Wah won't work. You'll have to step down on the toe switch to go to EXP2. Which is how I would want it anyway. I would want to start with the Volume pedal engaged and a press of the toe swtich to toggle between the wah and volume pedal. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted March 1, 2021 Share Posted March 1, 2021 I thought I noticed something odd so I tested a theory. Backstory: I think it may be probable I am unlike many of the folks who regularly participate here in that I do 99+% of all my editing work right on the unit. I very rarely use HX-Edit to make patches or to edit them. Mostly I use it for backing up my edits and for loading new ones. That's because I use my Helix as a pedal board. It's not a user interface for my computer. It plugs into a guitar amp. If I am editing, I want to hear what I'm doing in real time and I couldn't be bothered to go to all the work of dragging the amp and the Helix around and figuring out how to reconnect, etc. What I thought I noticed was that a couple of the patches that I did modify using HX-Edit were ones where the wah worked as expected. To test my theory, I connected Helix to the computer and used HX-Edit to remove and then reinstall the wah on one of my non-working-wah presets. I reconnected to the amp and found it had worked so I banked through all of my patches to take note of the ones that the wah didn't work on and then connected to HX-Edit again and fixed them all the same way. Now they all work. Don't ask me. I have no idea why. I'm not a Helix expert. I just use the thing. It's probably some kind of global setting but I have browsed them all and didn't see anything that jumped out at me. All I know is my patches work now and they didn't before. Maybe this will help the OP? Quote Link to comment Share on other sites More sharing options...
