Identifying Variax model
I'm thinking about buying a used Variax, and there's a chance I might not be able to give it a full test before purchasing. Three questions:
1) Can anyone identify this Variax model?
2) What are the tell-tales one should look for when considering buying a used legacy Variax like this?
3) With my rig I use keyboard emulation pedals (EHX Mel9, B9). I've noticed that different pickups push the pedals very different, with weaker pickups producing less of a signal from the pedal. Does anyone think the Variax might not send enough signal to push the pedals, based on the pickups it uses?
Thanks very much!
Image may contain: guitar and indoor
No photo description available.
Thanks very much!
Hi!
1. Looks like a Variax 500 to me. I have exactly the same guitar. Your serial number might indicate that it was manufactured in 2003.
2. Check so all the sounds play as expected. Check so the model knob switches sounds as expected. Check so the neck is straight. See so you can return the item to the seller if you decide to.
3. You can always trim your output signal for the different models with  Variax workbench or just use a clean boost pedal to unify your gain.
Hope this helps
  • 4 years later...
Can someone help me identify my Variax? I got it used several years ago. and never used it since I bought it. I downloaded a manual but they don't quite match so I need to find a manual by model number. There is some sort of what looks like a covered jack next to the quarter inch plug and not sure how to access it and am afraid to break it.Isthere som sort of special plug for that other jack and if so is there other hardware involved? SN is IMG_0632.jpg05020520
On 2/24/2025 at 10:55 PM, Dawkman said:
Can someone help me identify my Variax? I got it used several years ago. and never used it since I bought it. I downloaded a manual but they don't quite match so I need to find a manual by model number. There is some sort of what looks like a covered jack next to the quarter inch plug and not sure how to access it and am afraid to break it.Isthere som sort of special plug for that other jack and if so is there other hardware involved? SN is Can someone help me identify my Variax? I got it used several years ago. and never used it since I bought it. I downloaded a manual but they don't quite match so I need to find a manual by model number. There is some sort of what looks like a covered jack next to the quarter inch plug and not sure how to access it and am afraid to break it.Isthere som sort of special plug for that other jack and if so is there other hardware involved? SN is05020520
The special jack is for the Variax Digital Interface (VDI). It supports communication with a computer for a guitar model editor called Workbench, and supports firmware updates which you probably won’t need since there haven’t been any for many years and won’t be again. It also supports communication and interaction with certain old Line 6 guitar amp and FX processors.
Search for Line 6 VDI if interested.
