pete001 Posted February 23, 2014 Share Posted February 23, 2014 Hello all, I am the owner of a new JTV69S in shoreline gold-very happy with it. However I cannot get it to show in Workbench HD, it appears to see the guitar, then starts to load the presets and after the first one it immediately gives the error as shown in the attached picture:One or more presets failed to load from the guitar. (Code 8000000a) Operation timed out. Curiously Workbench also shows it as a JTV59 which it isn't. I am connecting via the the supplied USB interface and both lights are on green, using the latest version of all relevant software. Guitar shows up in L6 Monkey just as "Tyler Variax" and is on the latest V2 HD firmware. Using an i5 iMac with OSX Mavericks loaded 10.9.1. The guitar itself seems to work fine on its own. Any clues? Thanks Pete Quote Link to comment Share on other sites More sharing options...
cwelling Posted February 26, 2014 Share Posted February 26, 2014 I'm having the exact same issue Quote Link to comment Share on other sites More sharing options...
pete001 Posted March 5, 2014 Author Share Posted March 5, 2014 Just for info, after discussions with L6 tech support and trying several suggestions (using a different USB and CAT5 cable/different computer) it appears my JTV is faulty and I am about to return it for a replacement/repair. Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 5, 2014 Share Posted March 5, 2014 Are you sure you have the 2.0 firmware on the guitar? If you have an earlier firmware version, Workbench HD won't work with it. Quote Link to comment Share on other sites More sharing options...
alexdreamworld Posted March 8, 2014 Share Posted March 8, 2014 i have the problem similary with my jtv89f. Verify firewall and antivirus . i have kaspersky 2014 and i resolve a little the problem just one inactivate. i search a solution. i no think then the guitar is the problem because with workbench hd if i upload all presets on the variax jtv , it's ok. Using an Windows 7 (64 bits pro) Excuse me for my little english, i m french ;-) Quote Link to comment Share on other sites More sharing options...
alexdreamworld Posted March 8, 2014 Share Posted March 8, 2014 Hi, I test with a laptop with the same configuration ie windows 7 64bit pro, kaspersky 2014 and downloading the 60/60 on workbench hd,was a success so it does not come from antivirus or firewall.What is certain is that the technician Line 6 was the same as you have returned the guitar on my side it's not me the guitar that problem! Quote Link to comment Share on other sites More sharing options...
pete001 Posted March 21, 2014 Author Share Posted March 21, 2014 A quick update post for those who who may be interested. The guitar was returned to L6 who replaced the battery module I think. On return of the guitar it still had the same problem in workbench which was disappointing and starting to make me worry generally about reliability. I spoke with helpful staff at GuitarGuitar and was persuaded to try a replacement model JTV69S, I was assured they they get very few variax returns with few repairs needed. I am happy to say the replacement guitar works flawlessly and I am really pleased with it, just as a strat copy with its own magnetic pickups it sounds very good and the models do sound convincing to me and more importantly make me want to play more and try new things. Cheers Pete Quote Link to comment Share on other sites More sharing options...
alsithi Posted April 25, 2014 Share Posted April 25, 2014 I had the same problem- I solved it by removing the battery! Incidentally the battery was completely flat, so I will charge it and try again and see if that make any difference. I use my '69 via VDI into my HD500 so the battery never gets used (or does it?) and of course one design flaw (well, I think it is a flaw) is the battery can only be charged OFF the guitar. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 25, 2014 Share Posted April 25, 2014 Battery is not used or even necessary when using the JTV with a pod through the VDI cable. Lithium batteries often require a separate charger. Proper charging is critical. Quote Link to comment Share on other sites More sharing options...
stringtheory08 Posted May 1, 2014 Share Posted May 1, 2014 Same issue, Error Code 8000000a on every reboot. Reboot of Edit and unplugging hardware does correct but then the cycle repeats! Quote Link to comment Share on other sites More sharing options...
