spjunkie Posted April 12, 2021 Share Posted April 12, 2021 I have an HX stomp with 3.1 firmware on it now, and my m-audio expression pedal no longer works with it. As I rock the pedal I get either an "expression 1 active" or "expression 2 active" message. I am trying to assign it for position on a wah block. I had no problems with the previous firmware, is this a bug in 3.1? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 12, 2021 Share Posted April 12, 2021 After you updated, did you restore your Global Settings from the backup you made before the update? Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 12, 2021 Author Share Posted April 12, 2021 yes, as all my presets transferred over so I assume yes. Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 12, 2021 Author Share Posted April 12, 2021 Did go into global settings, set the tip polarity inverted, then assinged the wah to exp 2 in HX edit. It works but in reverse.. and it used work as exp 1, which all the blocks default to.. Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 12, 2021 Share Posted April 12, 2021 6 hours ago, rd2rk said: After you updated, did you restore your Global Settings from the backup you made before the update? 6 hours ago, spjunkie said: yes, as all my presets transferred over so I assume yes. That is not a good assumption for the question "rd2rk" asked. Did you actually do a full restore after the update? Or did you just see all your presets there and figure things were good to go? Presets are retained and "rebuilt" during an update. Global settings are not. You must restore your global settings, or reset them manually after an update. 2 Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 14, 2021 Author Share Posted April 14, 2021 how do I do this? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 14, 2021 Share Posted April 14, 2021 14 minutes ago, spjunkie said: how do I do this? You can use HX Edit. Use 'File' --> 'Restore From Backup' on the menu and select your old backup. Then uncheck everything(unless you want something else restored) with the exception of the global settings. Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 14, 2021 Author Share Posted April 14, 2021 8 minutes ago, HonestOpinion said: You can use HX Edit. Use 'File' --> 'Restore From Backup' on the menu and select your old backup. Then uncheck everything(unless you want something else restored) with the exception of the global settings. will this overwrite my presets? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 14, 2021 Share Posted April 14, 2021 11 minutes ago, spjunkie said: will this overwrite my presets? No, not unless you leave the checkboxes for your setlists checked. That is why you want to be careful to uncheck everything but the global settings before you trigger the restore(last step in the restore process). Always a good idea to take a precautionary backup first just in case though. Don't use the new backup for the restore though as it will have your current global settings instead of your old ones. Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 14, 2021 Author Share Posted April 14, 2021 Ok backed up just the global settings, the m-audio pedal is now working as it should. 1 Quote Link to comment Share on other sites More sharing options...
spjunkie Posted April 14, 2021 Author Share Posted April 14, 2021 On a lighter note, am I the only one who has to play Joe Raposo's Three's Company theme whenever you use the "colorful" wah? I've always wondered what wah he used.. It sounds the same on all the work he did for CTW and Sesame Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 14, 2021 Share Posted April 14, 2021 3 hours ago, spjunkie said: On a lighter note, am I the only one who has to play Joe Raposo's Three's Company theme whenever you use the "colorful" wah? I've always wondered what wah he used.. It sounds the same on all the work he did for CTW and Sesame In keeping with the Three's Company theme I will now refer to the "colorful" block as the "ménage à wah". 2 Quote Link to comment Share on other sites More sharing options...
codamedia Posted April 15, 2021 Share Posted April 15, 2021 15 hours ago, spjunkie said: On a lighter note, am I the only one who has to play Joe Raposo's Three's Company theme whenever you use the "colorful" wah? I've always wondered what wah he used.. It sounds the same on all the work he did for CTW and Sesame Tommy Tedesco was the guitar player that actually played the intro. Tommy kept immaculate notes and details about every session, I'm sure the info is out there somewhere. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 15, 2021 Share Posted April 15, 2021 1 hour ago, codamedia said: Tommy Tedesco Wrecking Crew member and top session man. Brilliant! 1 Quote Link to comment Share on other sites More sharing options...
