velfax Posted September 10, 2021 Share Posted September 10, 2021 Hi, does anybody know how to adjust the amount of volume given? I don't know how to explain my problem but it's like the volume knob of a fender amp. When you turn to 1 or 2 you almost have full volume. It feels like the first half inch of movement the expression pedal gives 70% volume right away. It doesn't feel natural and is hard to control with the foot. I couldn't find nothing about this on the manual, and I don't even know if it is possible to adjust that. Thanks in advance Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 10, 2021 Share Posted September 10, 2021 59 minutes ago, velfax said: I don't know how to explain my problem but it's like the volume knob of a fender amp. When you turn to 1 or 2 you almost have full volume. In the Volume pedal block the "curve" setting can be set to Linear (default) or Logarithmic. Change that to Logarithmic and it will behave more like a real volume pedal does... providing a more gradual volume throw. (NOTE: This is in the VOLUME PEDAL block you add to a preset, not the EXP adjustments in global settings) 1 Quote Link to comment Share on other sites More sharing options...
rbedsaul1 Posted August 7 Share Posted August 7 I have a related question... I have the Helix LT and the expression pedal is kind of 'sticky' (this is a physical issue, not a software issue). I use it the pedal for overall volume control at the end of my signal chain. If I push the toe down just a little bit for very low volume, the pedal doesn't stay in place - it comes back to the full upright position. I have to toe the pedal down at least 1/3 or 1/2 way down for the adjustment to take hold. Is there a particular lubricant or other mechanical remedy / adjustment that will fix this? Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 7 Share Posted August 7 I think (not 100%sure) the LT comes with a hex wrench to adjust the nut on the side of the volume pedal. Might just need a physical adjustment. Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 9 Share Posted August 9 On 8/7/2025 at 3:25 PM, rbedsaul1 said: I have a related question... I have the Helix LT and the expression pedal is kind of 'sticky' (this is a physical issue, not a software issue). I use it the pedal for overall volume control at the end of my signal chain. If I push the toe down just a little bit for very low volume, the pedal doesn't stay in place - it comes back to the full upright position. I have to toe the pedal down at least 1/3 or 1/2 way down for the adjustment to take hold. Is there a particular lubricant or other mechanical remedy / adjustment that will fix this? Thanks! I've used graphite spray on it, and it has been very solid and non-sticky for 3 years now. Do it at your own risk though. I didn't disassemble it, just sprayed at all the points where there was friction. Quote Link to comment Share on other sites More sharing options...
