MGW-Alberta Posted September 16, 2021 Share Posted September 16, 2021 Never mind. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 16, 2021 Share Posted September 16, 2021 Not sure what you mean. You can assign a Stomp to call a Snapshot using CommandCenter. You can assign a Snapshot to Bypass (or not) any or all FX, whether assigned to Stomps or not. Something else? Quote Link to comment Share on other sites More sharing options...
waymda Posted September 16, 2021 Share Posted September 16, 2021 As per rd2rk's Q - I read your question as: Can a Snapshot change the assignment of effect bypass to swtiches so that as you change Snapshots different effects appear in the Stomp row for manual use? Is that right? If I've read the question right, then not that I'm aware of. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 16, 2021 Share Posted September 16, 2021 I'm pretty sure it's been requested on Ideascale. Do a search and vote for it. I'm guessing that it's not a high priority request, but who knows? Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 17, 2021 Share Posted September 17, 2021 What you CAN do is you can use the MIX parameter of various blocks where at 0%, it's inaudible. When it's inadible, then bypassed or not bypassed makes no difference. Snapshots allow you to control all parameters in your block. So I don't know your exact need, but you can assign like 4 blocks to the same footswitch in pedalboard mode, but depending on the snapshot, some blocks are mixed at 0% (meaning they are not audible), and the others are audible. So in effect, your stomps can "change" on a per-snapshot basis... if you mute certain blocks and unmute the others. For example you can assign vibrato, delay, reverb to footswitch 1. In snapshot 1, delay and reverb are mixed at 0%, but vibrato is mixed at 30%. In snapshot 2, vibrato is mixed at 0%, but the other 2 blocks are mixed at 40%. So using the same footswitch, your sound will change differently. Your one switch controls vibrato or delay + reverb depending on which snapshot you're in. 1 Quote Link to comment Share on other sites More sharing options...
